I couldn't agree more - seems ridiculous that you can't exclude something like this from an MRP run - I have tried 'other' but it won't do it if it is an inventory item
Adrian
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cathy
Sent: 09 November 2012 16:45
Subject: RE: [Vantage] Exclude a PO from MRP
The real problem is that you should be able to buy a Part Number to an “Other†instead to Inventory.
Other ERP Systems let you do this –
Look at all the hassle you need to go through so it doesn’t show up on MRP.
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of Adrian Lauchlan
Sent: Thursday, November 08, 2012 2:46 PM
Thank to everyone for their comments on this - I will discuss the options with production
Adrian
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf Of Mark Wagner
Sent: 08 November 2012 17:24
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: Re: [Vantage] Exclude a PO from MRP
Create the job and on the material tab select purchase direct. Create a PO and select job material to purchase for that job. Lock the quantity and/or date on the PO if you dont want MRP giving you messages to move in or move out. MRP will plan around the PO and will leave it along as long as you are already fulfilling the supply for that job
From: adrian.lauchlan <adrianlauchlan@... <mailto:adrianlauchlan%40gmail.com> <mailto:adrianlauchlan%40gmail.com> <mailto:adrianlauchlan%40gmail.com> >
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Sent: Thursday, November 8, 2012 4:58 AM
Subject: [Vantage] Exclude a PO from MRP
I want to exclude a PO from MRP because it is being used by R&D and I will need MRP to ignore this so that Production get sufficient stock if needed. I am thinking of several scenarios to achieve this:
• Create a new part for R&D - say RD-370024F and make sure it isn't an MRP item - don't think Inventory guys would be happy with this
• After sending the PO unapprove it and or put it on hold - haven't tested this but I am sure it wouldn't get picked up by MRP - then approve it either post MRP or when the items arrive - requires someone to remember to unapprove and then not question why an unapproved PO has been received
• Raise a Sales Order to ourselves for the quantity - cancel the Sales Order on receipt of PO - again requires managing
Anyone out there found a neat way of dealing with this?
Adrian
Adrian
Adrian
Adrian
