Hello all!
I am working on an SSRS in Report Builder 3.0. Here is a simplified version of my problem.
I have designed a BAQ that lists the operations, materials, and assembly part numbers for a specific job. For example in the BAQ I might get 10 rows for a job that has 5 operations and two materials. Each op is listed twice, once for each material.
This is fine for my report. I can use the hidden property, along with the ‘previous’ function to hide the duplicate op row. However, when I look at the hourly totals for a job (sum of all ops), the total is including the sum from the duplicate ops as well. My problem is that I can hide the extra op rows, but the data still gets added to the total row.
How can I tell my total row (or expression) to sum only each unique operation for a job, or better yet, sum only the visible rows?
ROW_NUMBER() OVER (PARTITION BY Jobs.JobHead_PartNum, Jobs.JobAsmbl_PartNum, Jobs.JobOper_OprSeq ORDER BY Jobs.JobHead_PartNum, Jobs.JobAsmbl_PartNum, Jobs.JobOper_OprSeq )
Then in my SSRS total expression, I changed it to:
A “nudge” was the best I could give, as I’m not really up to speed on the proper use of them. Only that I did use them in the past. Like you, it was mostly trial and error.
I just ran into an issue where this row number function works for one BAQ, but gives a server error on another BAQ. I had to increase the queryTimeout to allow extra processing time.
