Excluding Part Class from Inventory count in 8.03
I have a similiar need, and the problem is that the Manual part selection is one of those searches that only allows you to select one part at a time. So while you can do a quick search or BAQ search, you have to select them one at a time which takes forever.
Sent: Wed, December 16, 2009 1:29:58 PM
Subject: RE: [Vantage] Excluding Part Class from Inventory count in 8.03
Â
Paul
Could you, instead of using the 'full physical' function, select the
parts in Count Group entry you want to check with a BAQ search which
excludes the part classes in the BAQ?
I haven't tested this, but it's an idea?
Gary
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of PaulS
Sent: 16 December 2009 1:28 PM
To: vantage@yahoogroups .com
Subject: [Vantage] Excluding Part Class from Inventory count in 8.03
All,
Has anyone come across a way in Vantage 8 to exclude parts from
inventory counts based on part class? I know this has come up in the
past, but I am not sure if anyone ever succeeded in doing this.
Thanks!
Paul
All,
Has anyone come across a way in Vantage 8 to exclude parts from inventory counts based on part class? I know this has come up in the past, but I am not sure if anyone ever succeeded in doing this.
Thanks!
Paul
Paul
If you are talking about perpetual and not a full physical you can setup
a low ABC (Z) code, setting the cycle time to 9999. Any part with the
part class excluded, set the Min ABC to this ABC code
You could use a BPM to set the Min ABC automatically based on the part
class selected
Gary
Of PaulS
All,
Thanks!
Paul
Epicor 9 allows the exclusion of classes from Cycle Counting.
----- Original Message -----
Sent: Wednesday, December 16, 2009 7:17 AM
Paul
class selected
Gary
Of PaulS
All,
Thanks!
Paul
Chris / Gary,
Sorry, I should have been more clear; it is for the Year End Inventory...
Thanks!
Paul
--- In vantage@yahoogroups.com, "PaulS" <psiebers@...> wrote:
> All,
> Thanks!
> Paul
Paul
Gary
Of PaulS
All,
Thanks!
Paul
