Excuting 4GL code Problem
The BPM will not let you define a temporary table within the BPM designer or least I have never been able to.
If you are just looking up data from the Jobhead access it directly, no need to use a temporary table. temporary tables typically only come into play if you want to use the Business Objects for that table.
FOR EACH ttPartTran WHERE (ttPartTran.JobNum="008236" AND
> ttPartTran.TranType="MFG-STK"), each JobHead Where
> JobHead.JobNum="008236":
If you really need to have temporary tables have the BPM call a .p file within which you can define a temporary table. You can pass over values from the BPM including the ttPartTran dataset to the .p file.
Jim Kinneman
Senior Consultant
Encompass Solutions, Inc
--- In vantage@yahoogroups.com, "Herby Dallard" <hdallard@...> wrote:
> I am trying to execute the following 4GL code in a BPM Post-Proc action
> directive -Vantage 803.408B.
> I am trying to produce a running total of a PartTran's TranQty for a
> specific Job Number(small test before a mass update).
> However I keep getting the following error
> Exception caught in: Epicor.Mfg.BO.BpMethod
> Error Detail
> Message: Compilation error: You cannot define a TEMP-TABLE inside an
> internal procedure. (3355)
> ** Could not understand line 18. (196)
> Type: Error
> Program: Bpm/Misc.p
> Method: DeployProcedure
> Table:
> Row:
> Field:
> My Code: FYI: The problem is properly defining a temp table for JobHead that
> I can use in this BPM directive. Any assistance or example will be greatly
> appreciated.
> Thanks.
> Define Temp-Table ttJobHead
> Like JobHead.
> Define Input-Output Parameter Table for ttJobhead.
> Procedure JobHeadNum01Update:
> Define Variable iTranQtyRunTotal As Integer.
> ttPartTran.TranType="MFG-STK"), each ttJobHead Where
> ttJobHead.JobNum="008236":
> iTranQtyRunTotal=iTranQtyRunTotal + PartTran.TranQty.
> RUN lib\UpdateTableBuffer.p(Input BUFFER JobHead:HANDLE, 'Number01',
> iTranQtyRunTotal).
> END.
> End Procedure.
> Best Regards,
> Herby Dallard
> Information Technology Engineer
> Endicott Research Group
> hdallard@...
> 607-754-9187 ext. 3078
> www.ergpower.com <http://www.ergpower.com/>
Error Detail
Type: Error
Program: Bpm/Misc.p
Table:
Row:
Field:
appreciated.
Thanks.
Like JobHead.
iTranQtyRunTotal).
END.
End Procedure.
Best Regards,
Herby Dallard
hdallard@...
Where are you running this? If it's attached to a Job method you shouldn't
need to create a temp table, as it should already be there.
If you're running it somewhere else, I'd just drop the temp table as you
shouldn't need it.
Also, you may find it easier to just write some 4gl and compile it instead
of trying to run mass updates through BPM-land. You know your situation
better than I do though.
> Error Detail
> Type: Error
> Program: Bpm/Misc.p
> Table:
> Row:
> Field:
> that
> appreciated.
> Thanks.
> Like JobHead.
> iTranQtyRunTotal).
> END.
> End Procedure.
> Best Regards,
> Herby Dallard
> hdallard@...
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
I am running BPM Method Directives ReceiptsFromMfg which has PartTran
already there but I need the running total to sum to JobHead.Number01 (UD
field) which is not there.
If I chose to write it in 4gL as I am but compile it. IS this correct
I would do this from Open Edge Data Administration and open the procedure
editor. Write and verify syntax and compile it but make sure I a connection
to a Pilot or test DB?
Thanks for the quick reply.
Best Regards,
Â
Herby Dallard
hdallard@...
www.ergpower.com
Waffqle
Sent: Tuesday, November 22, 2011 10:48 AM
Subject: Re: [Vantage] Excuting 4GL code Problem
shouldn't need it.
> Error Detail
> Type: Error
> Program: Bpm/Misc.p
> Table:
> Row:
> Field:
> that
> appreciated.
> Thanks.
> Like JobHead.
> iTranQtyRunTotal).
> END.
> End Procedure.
> Best Regards,
> Herby Dallard
> hdallard@...
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
