Explain this cast &*#($&#
So I normally use Erp.Tablesets.PartMtlRow in VisualStudio externally with no problems.
When trying to use it within E10 I get this error:
Unable to cast object of type ‘PartMtlRow’ to type ‘Erp.Tablesets.PartMtlRow’.
Ok, so where else is PartMtlRow defined?
	foreach (PartMtlRow row in adapterBOM.BomSearchData.PartMtl.Rows)
                if(row.PartNum == PartNum)
					PartInfo thePart = new PartInfo();
					thePart.PartNum = PartNum;
					thePart.MtlSeq = row.MtlSeq;
					thePart.UOM = row.UOMCode;
Erp.BO.BomSearchDataSet.PartMtlRow
Thanks, let me give that a shot!
I’ve run into this issue several times. I am curious to know the reason behind the different classes with the same name.
Nailed it, thanks sir!
Much prettier:
		var arow = (from Erp.BO.BomSearchDataSet.PartMtlRow r in adapterBOM.BomSearchData.PartMtl.Rows
		where r.MtlPartNum == PartNum
		select r).FirstOrDefault();
		if(arow == null) throw new Exception("Couldn't find PartNum: "+PartNum+" in the BOM");
					thePart.MtlSeq = arow.MtlSeq;
					thePart.UOM = arow.UOMCode;
					return(thePart);
