Recently we were required to take out our first Export License for
shipment of military components overseas. Does anyone info on how to
track shipments associated with the license in Vantage? Do you set up a
sales order for the license or is there some other method? We would
appreciate any insight available in this regard.
Thanks!
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 3114
Fax: 262-252-4974
Email: paul.pachniak@...
<mailto:paul.pachniak@...>
WWW: http://www.aceprecision.com <http://www.aceprecision.com>
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
Thanks!
Paul E. Pachniak
Accounting Manager
Fax: 262-252-4974
