Export, Save As - Can’t select location? (only “Server:\”) - Same as an old one
So I am experiencing the same issue that this topic was originally about. Unfortunately I’m not familiar with Premise or what a “SaaS” customer is. So, is there a way to specify WHERE you want your export of a price list saved?
I apologize for the repeat of this question
Epicor version: 10.2.100.43
Thank you!
As an On-Premises customer you can control your Epicor environment and choose where you want your info can be saved. As a SaaS customer, everything is on the Epicor Cloud so info can’t be saved locally. You will need to use the Server File Download to be able to download any info as needed.
Thank you for the information, I appreciate the time you took to respond!
