Exporting Crystal 8.5 on Citrix
We have a new Citrix Server setup and I am having trouble exporting
Crystal Reports (version 8.5 on Vantage 6.1). I tried unloading and
reloading Crystal but I would only get a "No export DLL's found"
error. I shuffled the dll's around and I finally was able to get it to
export when I was working with Crystal that was loaded on the root
drive of the Citrix server. However, if a user, or even myself, tried
to export the report from their favorites bar (logged into the data
server), I would get a "Parameter has invalid structure size" error,
which is meaningless error as it would not work even on a report
without any parameters. Everything else about the report would work
fine, except for the export. Does Crystal use different dll's when it
is running on the Citrix server (an M drive or root Citrix drive) as
opposed to when you are running a compiled report on the data server?
It certainly seems like it does. I tried copying the dll's to various
spots on the data server but I am not sure where Crystal is trying to
look for the export dll's. Anyone have any ideas? I tried to export
the dll's from Crytal but I am not sure where to put them.
