Exporting from the Change Log
> We get the error:
> Syntax error in SQL statement
Interesting, do you have access to EpicWeb?
If so see link below:
https://epicweb.epicor.com/ReportServer/Pages/ReportViewer.aspx?/ePortal/ABDetail&rs:Command=Render&rc:Toolbar=true&Card_ID=8479MPS&Answerbook=Vantage%2fVista+8.0+-+General+Information+documents
--- In vantage@yahoogroups.com, Marco Vissuet <mvissuet@...> wrote:
> We get the error:
> Syntax error in SQL statement at or about 'TimeStamp, Chglog_0.DCDUserID, Chglog_0.)
> Marco Vissuet
> Systems Engineer
> Pacific Contours Corporation
> Cell (619)507-2311
> Anaheim Office (714) 693-1260
> San Diego Office (619)670-3900
> Fax (714) 693-1252
> mvissuet@...<mailto:marcov@...>
> http://www.pacificcontours.com/
> "The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties. Disseminate in accordance with provisions of DoD Directive 5230.25.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of b_ordway
> Sent: Monday, April 22, 2013 9:51 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Exporting from the Change Log
> > When we try to connect to the table using ODBC we get errors.
> Like the other post suggested, an Export BAQ might be a good route.
> Just curious though, what errors you are seeing? Progress?
> I only wonder because I've never had any trouble connecting to ChgLog.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "supertico05" <mvissuet@<mailto:mvissuet@>> wrote:
> > Does anyone have an easy way on how to export the data from the change log?
> > We are planning on purging the data in the change log, however, before we purge it, we want to export it to a excel file or text file.
Might not be fun but a BAQ on the table to populate a dashboard.
Let it run for the hour or two it might need to populate...
Then Copy and Paste.
Of course, I would just query the table in SQL and paste it into a file. If you are stuck with progress, try Squirrel or whatever it is that Vic is always harping about.
Tom Christie | Information Technology Manager | AGM Container Controls, Inc. | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of supertico05
Sent: Monday, April 22, 2013 8:44 AM
Subject: [Vantage] Exporting from the Change Log
You could create a BAQ and right click the results grid to export to excel.
Sent: Monday, April 22, 2013 11:43 AM
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
There is also a BAQ export process located under System Mgmt > Utilities
What about just dumping it out of SQL into excel. There are exporters out there that you could take the whole table to Excel as an archive type format.
Joshua Giese
CTO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
----- Original Message -----
Sent: Monday, April 22, 2013 10:54:33 AM
Subject: Re: [Vantage] Exporting from the Change Log
(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo ! Groups Links
We get the error:
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "supertico05" <mvissuet@...<mailto:mvissuet@...>> wrote:
What's your SQL query? I've never had a problem hitting this table.
Marco Vissuet
Sent: Monday, April 22, 2013 4:52 PM
Subject: RE: [Vantage] Re: Exporting from the Change Log
We get the error:
Chglog_0.)
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@... <mailto:mvissuet%40pacificcontours.com>
<mailto:marcov@... <mailto:marcov%40pacificcontours.com> >
Behalf Of b_ordway
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
log?
It's a progress database, so it's just through ODBC...
The only table being called is the change log table... we get the error regardless of what field(s) we try to call.
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Monday, April 22, 2013 2:06 PM
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Marco Vissuet
We get the error:
Chglog_0.)
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@...<mailto:mvissuet%40pacificcontours.com> <mailto:mvissuet%40pacificcontours.com>
<mailto:marcov@...<mailto:marcov%40pacificcontours.com> <mailto:marcov%40pacificcontours.com> >
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of b_ordway
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
<mailto:mvissuet@...%3cmailto:mvissuet@...<mailto:mvissuet@...%0b%3cmailto:mvissuet@...%3cmailto:mvissuet@...>> <mailto:mvissuet@...>> wrote:
log?
We have Progress and we do not have SQL.
I just linked the ChgLog table using ODBC connection in Microsoft Access
with no problems.
Do you think there might be corrupt data?
Marco Vissuet
Sent: Monday, April 22, 2013 2:12 PM
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Marco Vissuet
We get the error:
Chglog_0.)
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
Behalf Of b_ordway
<mailto:mvissuet@...%0b%3cmailto:mvissuet@...%3cmailto:mvissuet@...%3cmailto
log?
