Exporting to CSV file
Dustin,
You can create your BAQ Query and then use the BAQ Export Process to
dump that data to a folder every hour, for example. Then you can open
that CSV file in Excel.
Of melissa hietala
Sent: Friday, February 19, 2010 1:41 PM
Subject: [Vantage] Exporting to CSV file
Does anyone know if it is possible to take a custom report that is ran
off of the Vantage menu and export it directly to a CSV file?
Dustin Biniek
Does anyone know if it is possible to take a custom report that is ran off of the Vantage menu and export it directly to a CSV file?
Dustin Biniek
How is the report built? Via a query?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of melissa hietala
Dustin Biniek
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.733 / Virus Database: 271.1.1/2696 - Release Date: 02/19/10
02:34:00
Its a crystal report that is setup through an ODBC connection and then tied to the Vantage menu
Dustin Biniek
Sent: Fri, February 19, 2010 12:47:08 PM
Subject: RE: [Vantage] Exporting to CSV file
Â
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of melissa hietala
To: vantage@yahoogroups .com
Dustin Biniek
02:34:00
You can but it would be to excel...
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of melissa hietala
Sent: Friday, February 19, 2010 1:05 PM
Subject: Re: [Vantage] Exporting to CSV file
Dustin Biniek
<mailto:blake.clemens%40d-m-c.com> >
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of melissa hietala
Dustin Biniek
02:34:00
When you print preview the report, the icon to the far left is what you
want to use...
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of melissa hietala
Dustin Biniek
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of melissa hietala
Dustin Biniek
02:34:00
