Exporting using Report Builder
Oleg
In page properties set all margins to zero. Remove all Page header and
footer lines. Every line should begin with a quote that is NOT merged left.
Every other field on the line should be merged left.
I export to Excel. I put a quotes around numbers and text. Excel imports
them fine. If you're using other software you may have a problem with quotes
around numbers. Format your numbers with no commas if you don't have
quotes around them. If you're exporting text fields like comments or memos
and there are quotes in the text use a formula to replace them.
HTH
Russ Dover
On 23 Mar 01, at 13:45, Oleg Tumarkin wrote:
To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
Date sent: Fri, 23 Mar 2001 13:45:24 -0600
Send reply to: vantage@yahoogroups.com
Subject: [Vantage] Exporting using Report Builder
> I am trying to create a CSV file to use with our payroll software, the
> problem that I am running into is that no matter what I do the report
> starts with three blank lines and that throws off the importing software.
> There is no lines that should come up on the report, yet they do. Help.
> Does anyone know what causes this and what the work arounds are.
> Oleg Tumarkin
> Herker Industries
> To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other '
goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Russ Dover
rustover@...
717 336 2340 voice
717 336 2646 fax
717 336 7507 Days at work
Oleg Tumarkin
Herker Industries
Do you have all your page margins set for the report builder report set to 0
and all headers removed?
Oleg,
Also, in the Export setup window, select the "Once per band" option.
Regards
Jim Stetter
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Friday, March 23, 2001 2:56 PM
Subject: RE: [Vantage] Exporting using Report Builder
0
Removing the margins solved it, would have never guessed that. Thank you.
Sent: Friday, March 23, 2001 1:56 PM
0
Crystal Reports and other 'goodies', please go to:
Oleg,
Make sure you do not have a margin at the top or the bottom.
Chuck
Sent: Friday, March 23, 2001 1:45 PM
To: 'vantage@yahoogroups.com'
Oleg Tumarkin
Herker Industries
