I’m working on a workflow in ECM in our sandbox environment. Testing is going well, but I’d rather not recreate the entire workflow in production when the time comes to move to prod. Is there a way to export the workflow and then import into my production environment? I can’t find anything in the documentation, but if I’m honest I find the ECM documentation pretty lacking in comparison to what we get with the Kinetic ERP and the like.
The Admin > Import and Export feature will be where you want to look.
Thank you!
@pbrandvold
BEWARE - the Export routine will pull ANYTHING related to the object. If you pull a workflow, it’ll pull datalinks, content types, fields, etc.
And when you go to Import it - it will OVERWRITE anything named the same, without warning and without control.
