Dennis,
I do quite a bit of exporting also and I always export ASCII text out
of Vantage and save it with Notepad. Then I import/export the
Notepad .txt with MS Access 2000 because Access exports so cleanly.
Hope this helps
Joey
Hope this helps
Joey
--- In vantage@yahoogroups.com, "Dennis Houghton" <dennis@h...> wrote:
> Good morning group,
> I do a lot of exporting to text and prn files using a generic text
driver. I then use Monarch to select the data I need and from there
go to excel or access.
> The problem is that since I have upgraded my ops to xp pro and
office 2000, the data is unusable as it has extra characters and is
not in a usable format.
> Has anyone else had these problems and if so could you share your
solution with me? Any help will be appreciated.
> Thanks
> dennis
