# Extended UD Field Map Cache < 10.1.500 **Category:** [Epicor ERP 10](https://www.epiusers.help/c/e10/5) **Created:** 2016-11-17 15:03 UTC **Views:** 719 **Replies:** 1 **URL:** https://www.epiusers.help/t/extended-ud-field-map-cache-10-1-500/36340 --- ## Post #1 by @Edge Just an FYI if you are using Extended UD Field Mapping and it does not seem to work and you are on a version less than 10.1.500 please recycle your apppool / restart IIS. We had a caching issue that has now been resolved. --- ## Post #2 by @GaryL Thanks for this! I'm sure we would have restarted eventually, but this was the tip that made it a quick fix after todays changes. --- **Canonical:** https://www.epiusers.help/t/extended-ud-field-map-cache-10-1-500/36340 **Original content:** https://www.epiusers.help/t/extended-ud-field-map-cache-10-1-500/36340
