Extending OrderHed
Just as an update a restart of they physicals didn't make a difference. Bummer
--- In vantage@yahoogroups.com, "Anon" <jgiese@...> wrote:
> After extending the OrderHed table with OrderHed_UD I am getting an "Index was outside the bounds of the array" error. I have noticed that for every order I enter there are 2 rows created in the UD table. The full error text is below. No BPMs or screen customization's used. Please, anyone else have this issue?!
> Error Detail
> Index was outside the bounds of the array.
> Stack Trace
> at Epicor.Mfg.Core.UserDataHandler.loadData(UserDefined udd, DataSet ds)
> at Epicor.Mfg.Core.UserDataHandler.Load(DataSet udd, DataSet ds)
> at Epicor.Mfg.Proxy.SalesOrderImpl.MasterUpdate(Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel, SalesOrderDataSet ds)
> at Epicor.Mfg.UI.Adapters.SalesOrderAdapter.MasterUpdate(Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel)
> at Epicor.Mfg.UI.App.SalesOrderEntry.Transaction.Update()
Error Detail
Stack Trace
BUMP. Has anyone seen this ever? Please, this issue is jeopardizing our go live, and I have had discussions with Epicor on it, but no solid resolution. Anyone at all?
> Error Detail
> Stack Trace
Are you on SQL? Have you restarted your app servers?
> > Error Detail
> > Stack Trace
*John Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
We are on SQL64. All of the app server have been restarted, though the physical servers have not been restarted. Should I give that a shot?
> > > Error Detail
> > > Stack Trace
> *John Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
Can't hurt to try, but I hate to say that I rather doubt it will help.
Sounds like a bug in Epicor. What version are you on? I'll see if I can
replicate the issue if I have a VM on the right version.
> our go
> for
> anyone
> > > > Error Detail
> > > > Stack Trace
> ds)
> > *John Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@...*
> > *:: NO FAXES*
*John Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Restarting. There is an SCR for it
SCR 91076
SCR=91076, Part=_SCR-TOOL, Description=Call 1373577PSC: DEV 11387ESC CUST OrderHed_UD gives "Index was outside the bounds of array", Priority=Medium, Severity=3 - Error Workaround, Type=Tools, Module=TOL, Clientele ID=11387ESC, Target SP=9.05.608, Product=ICE-Tool, Status=Open-SCR
However I did find a way around it at one point, but that work around for whatever reason just stopped working one day. I'm just hoping someone else out there has found a work around.
> > our go
> > for
> > anyone
> > > > > Error Detail
> > > > > Stack Trace
> > ds)
> > > *John Driggers*
> > > *:: 904.962.2887*
> > > *:: waffqle@*
> > > *:: NO FAXES*
> *John Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
