External BAQ report errors
We occasionally get an error with a report based on an external BAQ. Â This BAQ report has one parameter, supplier ID. Â The user will enter a supplier ID, and get no report. Â The System Monitor says that the report completed with error "No records found." Â The user can then enter the same parameter and then the report appears on the screen as expected.
I do not think that this is a matter of the user mistyping the supplier ID, as it happens very frequently. Â
My view takes 8 seconds to run in SQL Server.
We have not seen this same problem with custom RDD reports or non-external BAQ reports.
Has anyone else experienced this issue?Â
Tanya Denison | IT Manager | NRS, Inc.
2009 S. Main Street, Moscow, IDÂ 83843
c: 208.301.0599 | p: 208.883.7834 Ext 277 | f: 208.882.1744
