Extract a company and merge it with another?
Setup = all of the supporting things that have to exist for transactions.
I.E. terms, ship via, sales categories, etc... the actual setups.
Configuration = all of the company configuration settings and the plant
company configuration settings too.
And yes, financial setups too. GL, and the data setups to support AP, AR.
Jose Gomez
Sent: Wednesday, April 10, 2013 11:51 AM
To: Vantage
Subject: Re: [Vantage] Extract a company and merge it with another?
What do you mean by Setup / Config? If its just the financials and things
like htat you'll be better off just setting them up the same way it wouldn't
take very long at all. You can import parts using DMT if that's what you are
talking about.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Wed, Apr 10, 2013 at 11:46 AM, Jim Chance <jim_chance@...> wrote:
> Could it be done if all I needed is the setup and configuration data?
> No transactions required.
> 1. .Identify tables for setup and config 2. DMT extract 3. DMT load to
> database into a new company
> We have a great deal of setup/config work done in a new company. We'll
> call it company B.
> In LIVE we have company A.
> Now that company B is been approved, rather than rebuild the config
> and setup files; can I get that data from company B and *ADD* it to
> company A in the LIVE database?
> Behalf Of Jose Gomez
> Sent: Wednesday, April 10, 2013 10:26 AM
> To: Vantage
> And DMT Wouldn't regenerate all the Part Tran records and such.
> I'd say cut your losses
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Wed, Apr 10, 2013 at 10:24 AM, Vic Drecchio
> <vic.drecchio@...>wrote:
> > A D&L wouldn't do it because you still have that Company field that
> > would need repopulating. I guess it's possible to do a search and
> > replace on the dumped ASCII text files.. but wow. DMT would be the
> > only potential way I can think of and I think it would still be a
> > hot
> mess.
> > Behalf Of Chris Robisch
> > Sent: Wednesday, April 10, 2013 10:16 AM
> > You might be able to do it with Dump/Load if you're on Progress.
> > Otherwise, Epicor might have a utility that'll do it. There are
> > files that don't have the Company in them, like the UserFile, that
> > need to be
> addressed.
> > ----- Original Message -----
> > From: "Joshua Giese" <jgiese@...
> > <mailto:jgiese%40wisconsinconverting.com> >
> > To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
> > Sent: Wednesday, April 10, 2013 7:08 AM
> > > What about dumping everything out updating in Excel and using DMT
> > > to put
> > the records into the desired DB?
> > > Joshua Giese
> > > CTO
> > > 920.437.6400 Ext. 337
> > > Site ID: 27450-E905700B2-SQL64
> > > From: "Jose Gomez" <jose@...
> > > <mailto:jose%40josecgomez.com>
> > > To: "Vantage" <vantage@yahoogroups.com
> > > Sent: Wednesday, April 10, 2013 9:06:22 AM
> > > No, company is EVERYWHERE ON THE DB you would have to copy every
> > > record
> > fro
> > > every table to the other DB and that would them blow up because
> > > your licencing wouldn't be in palce and your progress record id's
> > > would be messed up.
> > > This would be insane
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@... <mailto:jose%40josecgomez.com>
> > > http://www.josecgomez.com <http://www.linkedin.com/in/josecgomez>
> > > On Wed, Apr 10, 2013 at 9:58 AM, jim_chance <jim_chance@...
> > <mailto:jim_chance%40yahoo.com> > wrote:
> > >> Is there a way to extract a specific company from an Epicor
> > >> database
> > and
> > >> merge it with another company into another database?
> > >> I need to extract company A from TEST and merge it with company B
> > >> in
> > LIVE.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > > must
> > have
> > already linked your email address to a yahoo id to enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > > Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > <http://groups.yahoo.com/group/vantage/files/>
> > > (2) To search through old msg's goto:
> > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > must
> > have
> > > Builder and
> > > No virus found in this message.
> > > Checked by AVG - www.avg.com
> > > Version: 2013.0.3272 / Virus Database: 3162/6236 - Release Date:
> > > 04/10/13
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
Is there a way to extract a specific company from an Epicor database and merge it with another company into another database?
I need to extract company A from TEST and merge it with company B in LIVE.
No, company is EVERYWHERE ON THE DB you would have to copy every record fro
every table to the other DB and that would them blow up because your
licencing wouldn't be in palce and your progress record id's would be
messed up.
*Jose C Gomez*
*Software Engineer*
E: jose@...
What about dumping everything out updating in Excel and using DMT to put the records into the desired DB?
Joshua Giese
CTO
To: "Vantage" <vantage@yahoogroups.com>
messed up.
*Jose C Gomez*
*Software Engineer*
E: jose@...
You might be able to do it with Dump/Load if you're on Progress. Otherwise, Epicor might have a utility that'll do it. There are files that don't have the Company in them, like the UserFile, that need to be addressed.
To: <vantage@yahoogroups.com>
> Joshua Giese
> CTO
> From: "Jose Gomez" <jose@...>
> messed up.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> Version: 2013.0.3272 / Virus Database: 3162/6236 - Release Date: 04/10/13
A D&L wouldn't do it because you still have that Company field that would
need repopulating. I guess it's possible to do a search and replace on the
dumped ASCII text files.. but wow. DMT would be the only potential way I
can think of and I think it would still be a hot mess.
Chris Robisch
> Joshua Giese
> CTO
> From: "Jose Gomez" <jose@... <mailto:jose%40josecgomez.com> >
> To: "Vantage" <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
fro
> messed up.
> *Jose C Gomez*
> *Software Engineer*
LIVE.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Of
> Chris Robisch
> > Joshua Giese
> > CTO
> fro
> > messed up.
> > *Jose C Gomez*
> > *Software Engineer*
> and
> LIVE.
> have
> have
Jim,
What's in the company in Test that needs to be brought into the company in
Live? Is it some setup items (parts, vendors, etc.) or has it been running
transactions?
-Jeff
Jeff Greenaway
Consulting CIO/ERP Consultant
jeffgreenaway@...
www.cio-ondemand.com
Jose Gomez
Sent: Wednesday, April 10, 2013 7:26 AM
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...
> only potential way I can think of and I think it would still be a hot
mess.
addressed.
> > put
> > Joshua Giese
> > CTO
> > record
> fro
> > be messed up.
> > *Jose C Gomez*
> > *Software Engineer*
> >> database
> and
> >> in
> LIVE.
> > must
> have
> > Builder and
> > must
> have
> > Builder and
> > 04/10/13
Aside from updating the company ID in about 800 tables there is the problem of duplicate primary keys. You would have to parse through every table and insure that none of the primary keys in the source data exist in the target data. Then there are things like BPM�s. Do the BPM�s in company A now also fire off for company B? How do you deal with customizations? The list of issues goes on and on and the potential for error is enormous.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
> messed up.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
2. DMT extract
3. DMT load to database into a new company
We have a great deal of setup/config work done in a new company. We'll call
it company B.
Now that company B is been approved, rather than rebuild the config and
setup files; can I get that data from company B and *ADD* it to company A in
the LIVE database?
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...
mess.
addressed.
> > put
> > Joshua Giese
> > CTO
> > record
> fro
> > be messed up.
> > *Jose C Gomez*
> > *Software Engineer*
> >> database
> and
> >> in
> LIVE.
> > must
> have
> > Builder and
> > must
> have
> > Builder and
> > 04/10/13
wouldn't take very long at all. You can import parts using DMT if that's
what you are talking about.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> 2. DMT extract
> it company B.
> in
> the LIVE database?
> Of
> Jose Gomez
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> mess.
> addressed.
> > > put
> > > Joshua Giese
> > > CTO
> > > record
> > fro
> > > be messed up.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > >> database
> > and
> > >> in
> > LIVE.
> > > must
> > have
> > > Builder and
> > > must
> > have
> > > Builder and
> > > 04/10/13
