Fax Portion of APM
The fax and e-mail portion of APM is cheap. We use Microsoft Fax and it works great. The e-mail section also works well. The setup is simple and doesn't cost you a dime.
Â
Jonathan LangÂ
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
--- On Thu, 2/12/09, Brad Ebright <bebright@...> wrote:
Subject: RE: [Vantage] Re: Fax Portion of APM
Date: Thursday, February 12, 2009, 10:41 AM
How difficult was it to set up the built in fax on server 2003 and tie it
into APM? We are hoping to go low-buck on this project.
Thank You,
Brad Ebright
MGS Inc.
178 Muddy Creek Church Rd.
Denver, PA 17517
(717)336-7528
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
bw2868bond
Sent: Thursday, February 12, 2009 11:22 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Re: Fax Portion of APM
We are using the built in fax capability of Server 2003 and a USR
hanging on a COM port.
--- In vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com,
"brad.ebright" <bebright@.. .> wrote:
> Is anyone using the fax part of APM? If so, do you have any
> recommendations for which fax software/hardware to use? We are
looking
> into this now and dont know where to start.
> Thanks,
> Brad
recommendations for which fax software/hardware to use? We are looking
Brad
looking
> Thanks,
> Brad
We are using VSIfax with a single line fax modem right now. Seems to
be working alright.
looking
> Thanks,
> Brad
We use "Net SatisFAXtion" and have zero problems with it. The software
works great and is easy to use.
Blake Clemens
DMC
Of brad.ebright
Sent: Thursday, February 12, 2009 11:19 AM
Subject: [Vantage] Fax Portion of APM
Brad
We've had great success using the myfax.com service. You send to
email, but you incorporate the fax number in the email address. For
example, 15555551212@.... The service is reasonably priced and
has been easy to incorporate since there wasn't a fax server to setup
and maintain.
looking
> Thanks,
> Brad
We use FaxMaker by GFI. At the time had the best pricing/features for
us.
Jim
Of brad.ebright
Sent: Thursday, February 12, 2009 10:19 AM
Brad
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.234 / Virus Database: 270.10.20/1943 - Release Date:
02/10/09 07:20:00
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
bw2868bond
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
looking
> Thanks,
> Brad
Make sure you are using latest APM - 2.5 (I believe) because Server
2003 fax was not supported before that.
The only trick is to make sure Microsoft Document Imaging is the
default program associated with TIF files
tie it
> Thank You,
> Brad Ebright
> MGS Inc.
> Denver, PA 17517
> (717)336-7528
> _____
Behalf Of
> bw2868bond
> looking
> > Thanks,
> > Brad
