Faxing PO's from Vantage
We fax all of the Crystal forms using Simply Fax and have no problems.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Jerry Boyle" <jboyle@s...> wrote:
> We fax POs, Invoices, Packing Slips, and others (all Crystal forms)
using
> Zetafax and I have never seen this issue.
> Jerry Boyle, Controller
> Sipco Molding Technologies
> Meadville, PA. 16335
> p 814.724.2243 x53
> f 814.724.2244
> vantage 6.10
> -----Original Message-----
> From: Juliet Martin [mailto:jmartin@r...]
> Sent: Friday, January 21, 2005 4:44 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Faxing PO's from Vantage
> We get this too. I was told it was a Crystal Report Issue. You
will notice
> that it will do this on all Crystal Reports. Packing Slips,
Invoices, etc.
> Report Builder reports will run fine.
> If anyone knows how to fix this I would be very happy to know.
> From: tmsover [mailto:dnorris@b...]
> Sent: Friday, January 21, 2005 3:40 PM
> Subject: [Vantage] Faxing PO's from Vantage
> We have encountered a rather odd issue when trying to fax PO's from
within
> Vantage. We use Winfax Pro and print the PO to the Winfax print
driver. When
> viewing the PO during print preview it looks OK.
> When it comes out of a fax machine, the bottom portion of the PO
which
> details the line items has a box around it and the box is filled
with a gray
> background. I have also noticed this when using PDFfactory to save
it to a
> PDF.
> Is this a CR issue? Any thoughts?
Hello all:
within Vantage. We use Winfax Pro and print the PO to the Winfax
print driver. When viewing the PO during print preview it looks OK.
which details the line items has a box around it and the box is
filled with a gray background. I have also noticed this when using
PDFfactory to save it to a PDF.
Dale Norris
IS Manager
Bullen Ultrasonics Inc.
We get this too. I was told it was a Crystal Report Issue. You will notice that it will do this on all Crystal Reports. Packing Slips, Invoices, etc. Report Builder reports will run fine.
Juliet
Hello all:
Dale Norris
IS Manager
Yahoo! Groups Links
We fax POs, Invoices, Packing Slips, and others (all Crystal forms) using
p 814.724.2243 x53
f 814.724.2244
vantage 6.10
We have encountered a rather odd issue when trying to fax PO's from within
Vantage. We use Winfax Pro and print the PO to the Winfax print driver. When
When it comes out of a fax machine, the bottom portion of the PO which
details the line items has a box around it and the box is filled with a gray
background. I have also noticed this when using PDFfactory to save it to a
PDF.
Juliet, Dale,
This appears to be a printer driver issue. It happened to several computers
here (all running XP) until I edited the crystal form and made the gray box
just a little smaller (pushed the bottom up just a bit). Now everything
prints as it should.
Good luck,
Aaron Hoyt
Vantage Plastics
Juliet
Hello all:
Dale Norris
IS Manager
Yahoo! Groups Links
Yahoo! Groups Links
