Thanks! I'll give that a shot...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Andrew
Sent: Monday, September 21, 2009 11:48 AM
Subject: Re: [Vantage] Field won't display on Crystal Report
I had a similar issue when I added the CustID to an RMA Form. It showed up in Crystal Developer, and when I "printed" the form from my workstation, but when other users(who did NOT have Crystal Developer on their workstation) previewed or printed the form, the CustID would not print. The Data was in the XML. There is some sort of "issue" with the Crystal runtime. The fix (workaround really) was to uninstall the Crystal runtime, install crystal Developer, re-install the runtime, then un-unstall Crystal Developer. The field then printed on the form for the user(s) at that workstation. This may be something to try (if you don't have a lot of users workstations)
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Sprowles, Mark" <msprowles@...> wrote:
> I tried a simple formula - if IsNull([CustCnt.EmailAddress}) then "Blank" else {CustCnt.EmailAddress} and it came up with the word "Blank", yet when I edit the XML file I can see the correct email address there... (I have attached the XML file).
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]
> On Behalf Of Brian W. Spolarich
> Sent: Monday, September 21, 2009 11:06 AM
> Subject: RE: RE: [Vantage] Field won't display on Crystal Report
> What happens if you create a formula whose value is just the field in question and use the formula instead?
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix
> / Picometrix bspolarich@... <mailto:bspolarich%40advancedphotonix.com>
> ~ 734-864-5618 ~ www.advancedphotonix.com
> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> ] On Behalf Of Bill King
> Sent: Monday, September 21, 2009 11:05 AM
> To: 'vantage@yahoogroups.com <mailto:%27vantage%40yahoogroups.com> <mailto:%27vantage%40yahoogroups.com> '
> are you getting data to populate on the XML file?
> BILL R. KING
> J&B Industrial Services
> (806).776.4409 Office
> (254).592.4397 Cell
> ] On Behalf Of Sprowles, Mark
> Sent: Monday, September 21, 2009 9:59 AM
> Subject: RE: [Vantage] Field won't display on Crystal Report
> Yes... It is an XML based form, (a copy of the standard SOForm form Epicor), and once linked to a datasource it appears in design view as it should...
> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
> On Behalf Of IT Support
> Sent: Monday, September 21, 2009 10:56 AM
> Is the field populated prior to printing???
> Sent: Monday, September 21, 2009 9:53 AM
> I have set the form to have no default printer as suggested and no change... The field is not near the margin... Its so strange that I can print all other fields from this table in this spot but not the Email Address...
> Thx for the responses...
> ] On Behalf Of Charlie Wilson
> Sent: Monday, September 21, 2009 10:27 AM
> I have seen weird stuff like this happen when the field goes out into the margins.
> Also set the report to have no default printer.
> ~Charlie
> _____
> ] On Behalf Of m_sprowles
> Sent: Monday, September 21, 2009 10:21 AM
> Subject: [Vantage] Field won't display on Crystal Report
> I am trying to add a field, (CustCnt.EmailAddress), to a sales order form.
> When I browse the data in the field it appears as I need but when I
> print preview the form it does not show. When I add any other field
> from the CustCnt table it works as expected. Just the EmailAddress
> field has this peculiar behavior. I have added this field to a blank
> report and it shows as expected. I have reentered the email address to
> clean up any bad characters
> - no go...
> I am using Crystal Reports 11.5.3.417 with Vantage 8.03.407b. The form is using an ODBC connection...
> Any ideas?
> Thx in advance for any help...
> The information contained in this message is intended solely for the individual to whom it is specifically and originally addressed. This message and its contents may contain confidential or privileged information. If you are not the intended recipient, you are hereby notified that any disclosure or distribution, or taking any action in reliance on the contents of this information, is strictly prohibited.
> We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
> This message (including any attachments) is intended only for the use of the individual or entity to which it is addressed and may contain information that is non-public, proprietary, privileged, confidential, and exempt from disclosure under applicable law or may constitute as attorney work product.
> any use, dissemination, distribution, or copying of this communication
> is strictly prohibited. If you have received this communication in
> error, notify us immediately by telephone and
> (i) destroy this message if a facsimile or (ii) delete this message immediately if this is an electronic communication.
> Thank you.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> <http://groups.yahoo.com/group/vantage/files/.>
> <http://groups.yahoo.com/group/vantage/files/.> >
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/messages> >
> http://groups.yahoo.com/group/vantage/linksYahoo
> <http://groups.yahoo.com/group/vantage/linksYahoo>
> <http://groups.yahoo.com/group/vantage/linksYahoo> > ! Groups Links
