When setting up FIFO, I know you need to adjust quantities to zero, change the costing method and then adjust the parts back in with the FIFO cost. For parts that have a zero quantity, is a cost adjustment required or will the first layer create itself with the FIFO cost when the part is purchased or made for the first time?
Thanks, Tim
