Filter an EpiGrid (SOLVED)
Thanks Mr. Koch! Your input got me closer to the solution.
If anyone else runs into this challenge the solution is below. I placed this piece of code in an EpiViewnotification. After the user saves, the grid is regenerated with the filter applied.
Public Class Script
Private WithEvents DataSharingGrid As EpiUltraGrid
Public Sub InitializeCustomCode()
DataSharingGrid = CType(csm.GetNAtiveControlReference("5c9e9edc-61a0-4085-8701-839ad7248e57"), EpiUltraGrid)
End Sub
Public Sub DestroyCustomCode()
End Sub
Private Sub edvCustomer_EpiViewNotification(ByVal view As EpiDataView, ByVal args As EpiNotifyArgs)
Me.DataSharingGrid.Rows.ColumnFilters("Key3").FilterConditions.Add(Infragistics.Win.UltraWinGrid.FilterComparisionOperator.Equals, "DataSharing")
End Sub
End Class
--- In vantage@yahoogroups.com, Ted Koch <tkoch77@...> wrote:
> Hi,
> You could try using the AfterRowInsert event.
> From: chan213419 <chan213419@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, June 6, 2013 8:46 AM
> Subject: [Vantage] Filter an EpiGrid
> Good morning!!!
> I am trying to figure out how to filter an EpiGrid, and it appears that I am only half way there. The code below filters the grid just fine, but only when the grid is first initialized. I would like it to be filtered "live" so to speak (so when I add a new row it immediately pops up in the grid). Any suggestions or help would be greatly appreciated.
> Public Class Script
> End Sub
> End Sub
> Private Sub DataSharingGrid_InitializeRow(ByVal Sender As Object, ByVal Args As Infragistics.Win.UltraWinGrid.InitializeRowEventArgs) Handles DataSharingGrid.InitializeRow
> If Args.Row.Band.Index = 0 Then
> Â Â Â Â Â Â If Args.Row.Cells("Key3").Value <> "DataSharing" Then
> Â Â Â Â Â Â Â Â Â Args.Row.Hidden = True
> Â Â Â Â Â Â End If
> End If
> End Sub
> End Class
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Good morning!!!
Public Class Script
End Sub
End Sub
End If
End If
End Sub
End Class
Hi,
Good morning!!!
Public Class Script
End Sub
End Sub
      End If
End If
End Sub
End Class
