Ricky90
(Ricky Horne)
February 2, 2022, 3:16pm
1
Hi, I am in Price List Inquiry and when the Part Code changes i want to filter a grid from a BAQ I have created to show all Part Codes. I have tried to follow How To: Kinetic BAQ Grid Pub-Sub - Experts’ Corner - Epicor User Help Forum (epiusers.help) but this seems to lend itself towards Publish and Filter from the E10 Classic Dashboards.
I have the BAQ loading the DataView when the Part Changes, i was hoping using the right relationships from within the dataview but it didnt help filter out the BAQ results.
Current Settings below.
hmwillett
(Hannah Willett 🏳️🌈⚧)
February 2, 2022, 4:34pm
3
Sorry–I misread your question.
Is there a reason you want to do the filter in the DataView instead of what you currently have set?
What you show in your images is definitely the way to go for a dynamic filter.
Ricky90
(Ricky Horne)
February 2, 2022, 4:55pm
4
Hi @hmwillett
I was attempting to filter a baq by the PartNum that is chosen in price list inquiry and then show it within a grid.
hmwillett
February 2, 2022, 4:56pm
5
What you have should work. What issues are you running into?
Ricky90
(Ricky Horne)
February 2, 2022, 4:57pm
6
If I put the where statement in I get nothing returned. If it is empty I get the whole query (which I would expect).
Running the baq in the designer returns at least 1 row per PartNum
hmwillett
February 2, 2022, 5:03pm
7
Here’s what I created for reference (slightly different BAQ, but same idea).
PartWhse_PartNum = ?{PriceListInquiryCriteria.PartNum}
Ricky90
(Ricky Horne)
February 2, 2022, 8:02pm
8
Hi,
The query shows all rows when that WHERE clause is empty.
As soon as i put in Part_PartNum = ?{PriceListInquiryCriteria.PartNum} I get blank no records found.
I followed your instructions to the letter.
hmwillett
February 2, 2022, 8:25pm
9
Can you send me your BAQ?
I’ll give it a try with that and see what I can find out.
You might also try adding a second “?” which will allow for nulls. It may be choking on one.
Part_PartNum = ??{PriceListInquiryCriteria.PartNum}
Or try adding single quotes. The syntax in App Studio is duuuuuuuuumb and inconsistent.
Part_PartNum = '?{PriceListInquiryCriteria.PartNum}'
hmwillett
February 2, 2022, 8:26pm
10
Actually, you know what? Start with adding the quotes.
You may have part numbers where it necessitates those. Ours just happen to play nice.
Ricky90
(Ricky Horne)
February 2, 2022, 8:42pm
11
WINNER
The quotes looked to have sorted my issue here.
I will bear this in mind for future dealings with out PartNums.
Thank you!!
