Filter in Report Designer
So, trying to ad the Part_Typecode filter to a report at the Report Designer in Epicor. And it only shows Part_Partnum in the drop down box. Why? How do I add the Typecode?
For the BAQ Report Designer, you only can use in filter the fields of BAQs that are indexing by Epicor Enterprise Search Management.
First you must Add your BAQ into indexed BAQ using Epicor Administration Console, after the indexing process finished you can retur to BAQ Report Designer and use any columns of your BAQ like a filter.
