My pleasure Emily. Glad it worked!
Rob
--- Original Message ---
Sent:Fri 5/15/09 8:21 am
To:vantage@yahoogroups.com
Subj:[Vantage] Re: Filter to show only active Salespeople
That did it! Thank you very much!!
Emily
Rob
Emily
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...> wrote:
> Emily,
> I don't know what version you are on, but if you go into customization mode and look at each of the "SalesPerson" pulldown controls' properties, look for a property line called "Search Filter". If you enter (don't include quotes) "InActive=False" and, on the following properties line titled "Value Member" enter "SalesRepCode", save it as a customization (and menu activate it), the users should not be able to select (or even see) SalesReps that are not Active.
> If you find the app already set up like this and it is NOT preventing InActive SalesReps from being sleceted, report it to Epicor and get Support to get a SCR going for it (for whatever version you are on).
> Rob
> From: brz_larson <bl_larson@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, May 14, 2009 3:43:05 PM
> Subject: [Vantage] Re: Filter to show only active Salespeople
> You might try putting zzz in front of the names.
> THis would push them to the end of the list.
> I have used quick searchs in the past to filter out inactive resources, etc, when you click the search button. Pull downs are a little different.
> Bruce
> www.ERPgeek. com
> bruce@ERPgeek. com
> --- In vantage@yahoogroups .com, "emverbeke" <emverbeke@ ..> wrote:
> > I want the combo Salesperson fields that pull down to only show active salespeople in forms like the Order Entry and Quote Entry, etc. I thought I would be able to do it with a rule but the "inActive" field isn't available. Maybe there is just some easy setting that I'm missing rather than a customization. Any ideas are greatly appreciated.
> > Emily
