Just as an FYI, for those backflushing labor, the final operation indicates that any preceeding operations are eligible to be backflushed through the backflush labor process server. If the final operation on a MOM is checked, you only have to report quantity on that operation and your other operations will backflush the labor if those operations labor methods are set to backflush.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Monday, November 5, 2012 6:43 AM
Subject: RE: [Vantage] Final Operation - BOM
Â
In Vantage 6.1 and before, you had to flag this checkbox otherwise you would never get any completed quantity on your job.
As of Vantage 8 and in turn Epicor 9, this checkbox is only used by exception. In other words the system assumes the last operation sequence on assembly zero is the last operation
This checkbox is so you can use an operation prior to the last, in order to mark job quantity complete when quantity is posted to it.
The last operation sequence is stored in the PartRev and in the JobAsmbl tables, but updated via the Part Operation and Job Operation views You do not necessarily need to check this box for the system to work.
Gary
[cid:mailto:image491a56.GIF%40c5306ae5.47938236]
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Turgeon, Bill
Sent: 02 November 2012 19:52
To: mailto:vantage%40yahoogroups.com
That doesn’t help me…. There must be something on the Partopr that indicates which operation is the last one.
How does the Job know which is last? I remember indicating “FinalOper†on the DMT tool when importing our BOM’s way back when….
From: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mark Wagner
Sent: Friday, November 02, 2012 3:49 PM
To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>
Subject: Re: [Vantage] Final Operation - BOM
Its on the joboper table
From: "Turgeon, Bill" <mailto:bturgeon%40cotorelay.com<mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com> >
To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Sent: Friday, November 2, 2012 3:35 PM
I see it but it points to the ECO table… I’m looking at the PartOpr table
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Mark Wagner
Sent: Friday, November 02, 2012 3:18 PM
Its on the operations tab on your method of manufacturing in engineering workbench
From: "Turgeon, Bill" <mailto:bturgeon%40cotorelay.com <mailto:bturgeon%40cotorelay.com <mailto:bturgeon%40cotorelay.com%20%3cmailto:bturgeon%40cotorelay.com<mailto:bturgeon%40cotorelay.com%20%3cmailto:bturgeon%40cotorelay.com%20%3cmailto:bturgeon%40cotorelay.com%20%3cmailto:bturgeon%40cotorelay.com>> > >
To: mailto:vantage%40yahoogroups.com <mailto:vantage%40yahoogroups.com>
Sent: Friday, November 2, 2012 3:13 PM
Subject: [Vantage] Final Operation - BOM
Ok folks, I having a senior moment.... I know there is a field somewhere
that indicates the operation is the 'Final Operation'.
Be damned if I can find it.... Anyone?
Also, I may need to create a SQL view, but once created, how can I
access it via a BAQ?
Thanks!!
Bill Turgeon
Director, Information Technology
Â
Gary
Thanks!!
Bill Turgeon
