Thanks, Mike and Joanne. That's what I needed to do. Put the acct in once
and specify the range of depts. Now why didn't I think of that?
Terry L. Williams Chipsco, Inc. 9936 Liberty St. Ext. Meadville, PA
16335 814-333-6331 fax: 814-337-2548 tlw@...
<mailto:tlw@...> www.chipsco.com <http://www.chipsco.com/>
Sent: Monday, March 26, 2001 8:42 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Financial Report Designer 4.0
Terry
Just show the acct as 5115 to 5115 once with the depts as 01 to 01, 15 to
15, and 28 to 99. That should work for you.
Sent: Monday, March 26, 2001 8:37 AM
Terry, I think the problem is that there is not a one-for-one relationship
between the account code and the department range across the input page. A
range of department codes applies to every account listed. In effect, you
have asked for the same data three times.
Sent: Sunday, March 25, 2001 8:00 PM
Subject: [Vantage] Financial Report Designer 4.0
Anybody ever have any trouble with FRD adding account balances for
ALL ranges of charts/depts for every range of charts/depts set up?
Example: In one line item total, I have from chart 5115 to 5115 from
dept 01 to 01 as one range, chart 5115 to 5115 from dept 15 to 15 as
the next range, chart 5115 to 5115 from dept 25 to 99 as the third
range. The total g/l activity for these three ranges is 575000. I
verified that with an RB report. The FRD shows me a line item total
of 1725000. My calculator tells me that 1725000 / 575000 = 3. I
moved the 5115.01 over to the specific accounts and the line item
total was double the remaining 2 ranges plus the 5115.01 balance.
Then I moved 5115.15 over to the specific accounts side and left one
range of 5115 to 5115 from dept 25 to 99. That gave me the correct
total on the line item.
I looked on ERANet for reference to this specifically and also the
onelist archives and found none. Has anyone else had this problem?
I'm able to work around it (the loooooong way). Just curious, is
there a fix I don't know about?
TLW
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
< http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already
linked your email address to a yahoo id to enable access.
< http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
http://rd.yahoo.com/M=162801.1342103.2934627.1280005/D=egroupmail/S=1700007
183:N/A=599089/*
http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLer
<http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLer>
t_ComputersInternet_Software_WhiteGridOptions&t=ad> Click Here to Find
Software Faster
Click Here to Find Software Faster
http://us.adserver.yahoo.com/l?M=162801.1342103.2934627.1280005/D=egroupmai
l/S=1700007183:N/A=599089/rand=131695228>
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
< http://docs.yahoo.com/info/terms/> Service.
<http://rd.yahoo.com/M=162801.1342103.2934627.1280005/D=egroupmail/S=1700007
183:N/A=599089/*http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLer
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
Terry
TLW
already
183:N/A=599089/*
Software Faster
