FInancial Report Writer
Paul... believe it or not it is the print system in 98. W2K & XP everything
prints just fine. Thanks for your help.
Sent: Wednesday, January 08, 2003 9:29 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] FInancial Report Writer
Lois,
Does the data show up fine on the Excel sheet, or is the last digit being
lost in the transfer from Vantage data to Excel?
What you can always try is to create a second printer going to the exact
same physical printer, but tell Windows it is a HP LaserJet III....
That way you can select the printer depending on the source of the print
job.
HTH,
Paul
Sent: Wednesday, January 08, 2003 9:51 AM
THanks Paul. I found if I use HP 5 Vantage prints fine but then my Excel
spreadsheets that I print with imported vantage data cut off the last digit
of every field in the report. Any ideas on that one?
Sent: Monday, January 06, 2003 10:51 AM
I used to have a similar problem on a Lanier digital copier a coule of years
ago. Back then before Lanier came out with a new driver, the fix was to add
the Lanier using a HP LaserJet III or 4 driver....
Paul
[mailto:lheisey@...]
Sent: Monday, January 06, 2003 11:45 AM
Subject: [Vantage] FInancial Report Writer
My accountant has developed several reports using the Financial
Report Writer. None of the reports will print on my printers. The
only printer that we can get them to print on is the HP 1220. What
is going on with this? These are not large reports. I can't even
get them to print to my digital copier that is set up to print via
TCP/IP. Everything else in Vantage prints fine to all the printers.
We are on Vantage 5.00.345. Thanks for any help you can give me.
Paul
Paul
Lois,
job.
HTH,
Paul
Paul
