Financial Reports - Comparative %
On the specifications for the line on which you want your ratio to be based
(ex: Total Sales), you have to put a check where it says percent. Then all
your numbers in the ratio column will give you the ratio you are looking
for.
Nora Story
Spectra Technologies, Inc.
> Subject: [Vantage] Financial Reports - Comparative %
> In Financial Reporting (Income Statement) there are Columns called %
> Sales (Column 4 and Column 6) on the Standard Row which are
> Comparative % fields. Can anyone tell me how these work? ie. What
> values are compared as I only ever get zeroes in this field on a
> report.
> I need something to compare the Sales figure with the other values on
> my Income Statement Report to create a Statement of Operations and
> Earnings Report. I realise I can use the Ratio to do this but then I
> have to have another line on my report display this value. I would
> have preferred to have the % of Sales as a column on the Row it
> relates to. Note: The % of Sales I am referring to is the Row value
> divided by Sales value displayed as a percentage.
Can anyone please help me regarding the following?
report.
ps. Thanks for the help on the current company and User Id. I
discovered that the method Todd gave me actually gives the id of the
User logged on to the Server. This is not necessarily the user id
that I have used to log into Vantage. ie. I log into the Server as
Wendy and if I then log into Vantage as Manager, the reports I create
display the user id Wendy. However, the reports provided by Vantage
display the user id Manager. Does anyone know where the Vantage User
Id is?
Regards
Wendy
