Financial reports
You can still do that in 5.0.
Sent: Friday, March 15, 2002 12:24 PM
Subject: RE: [Vantage] Financial reports
Alex,
Unless some extreme changes have been made since V3 (what I am on), you
certainly CAN do summarized statements in the Financial Report Designer.
You
need to select the line type as "Summary", then specify ranges of charts
and/or departments.
Regards
Jim Stetter
Sent: Friday, March 15, 2002 11:55 AM
To: 'vantage@yahoogroups.com'
I would use the Financial Report Designer. Works much better than
report
builder for Financial Reports with comparisons to prior periods, years,
etc. The only downside to the Financial Report Designer is that you
have
to show all accounts numbers to get them to total (ie you can't have a
summarized financial statement). It is pretty easy to learn and now you
can duplicate reports.
If you want to use report builder, try the in-list command and filter by
'100','102'
Call me if you need help.
Alex Neutgens
Controller
Circuit Check, Inc.
763-694-4110
Sent: Friday, March 15, 2002 10:32 AM
Subject: [Vantage] Financial reports
Hello all. I am having difficulty trying to design an Income statement
which combines two separate departments which are not numbered
consecutively. In other words with departments 100,101, & 102, I am
trying
to build a statement that combines only 100 & 102. The problem I run
into
is that since I cannot name a range (i.e.100-102)
I tried putting the chart numbers in for both departments, for some
reason
the report writer keeps changing the sequence of both the charts and the
departments. Any suggestions?
Ron LaHolt
Company Controller
Rivers Metal Products, Inc.
3100 N. 38th St.
Lincoln, NE. 68504-1998
(402) 466-2329
have
and
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Yahoo! Groups Sponsor
ADVERTISEMENT
and
consecutively. In other words with departments 100,101, & 102, I am trying
to build a statement that combines only 100 & 102. The problem I run into
I tried putting the chart numbers in for both departments, for some reason
Ron LaHolt
Company Controller
3100 N. 38th St.
(402) 466-2329
I would use the Financial Report Designer. Works much better than report
etc. The only downside to the Financial Report Designer is that you have
'100','102'
Alex Neutgens
Controller
Circuit Check, Inc.
763-694-4110
Ron LaHolt
Company Controller
3100 N. 38th St.
(402) 466-2329
Alex,
certainly CAN do summarized statements in the Financial Report Designer. You
and/or departments.
Regards
Jim Stetter
'100','102'
Alex Neutgens
Controller
Circuit Check, Inc.
763-694-4110
Ron LaHolt
Company Controller
3100 N. 38th St.
(402) 466-2329
have
ADVERTISEMENT
