Find where a field is used?
If you are using Progress, you can use Progress' meta-schema file structure
to determine all the locations of field - Progress query.
Def var l-printer as logical
label "Printer output?" no-undo.
Def var c-field as char format "x(20)" label
"Field Name" no-undo.
Def var I as integer format ">>>9" label
"Count" no-undo.
Update c-field colon 40
l-printer colon 40
with frame f-in width 80 side-labels title "Find Field".
If l-printer = true then output to printer paged.
FOR EACH _file WHERE SUBSTRING(_file._file-name,1,2) <> "IM",
EACH _field OF _file WHERE
_field.field-name = c-field.
/* OR _field.field-name MATCHES "*comment*". */
/* _field._field-name MATCHES "*terr*". */
DISPLAY
i
_file._file-name FORMAT "x(20)"
_field._field-name FORMAT "x(20)"
_field._format FORMAT "x(10)"
WITH TITLE "Find fields with " + c-field.
END.
Carl Peterson
advantage
Sent: Tuesday, September 22, 2009 6:08 PM
Subject: RE: [Vantage] Re: Find where a field is used ?
I think what Kristi was asking; was HOW did you figure that out. I simply
peruse the Data Dictionary.pdf or use zDataFields?
Behalf Of
bw2868bond
Sent: Tuesday, September 22, 2009 5:25 PM
Subject: [Vantage] Re: Find where a field is used ?
AnalysisCode: Used in these tables
AnalysisCd
ECOMtl
ECOOpr
GlbPart
IMAnalysisCd
IMECOMtl
IMECOOpr
IMGlbPart
IMJobAsmbl
IMJobHead
IMJobMtl
IMJobOper
IMOpMaster
IMPart
IMPartMtl
IMPartOpr
IMQuoteAsm
IMQuoteDtl
IMQuoteMtl
IMQuoteOpr
JobAsmbl
JobHead
JobMtl
JobOper
Obsolete803-AnalysisCode
OpMaster
Part
PartMtl
PartOpr
QuoteAsm
QuoteDtl
QuoteMtl
QuoteOpr
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
"k_stump" <kristi.stump@...> wrote:
> Hi,
> I'm looking for ways to find where all a field is used - screens, reports,
etc. For example, where the AnalysisCode of the Part table is referenced.
> Thanks !
> Kristi
Hi,
I'm looking for ways to find where all a field is used - screens, reports, etc. For example, where the AnalysisCode of the Part table is referenced.
Thanks !
Kristi
AnalysisCd
ECOMtl
ECOOpr
GlbPart
IMAnalysisCd
IMECOMtl
IMECOOpr
IMGlbPart
IMJobAsmbl
IMJobHead
IMJobMtl
IMJobOper
IMOpMaster
IMPart
IMPartMtl
IMPartOpr
IMQuoteAsm
IMQuoteDtl
IMQuoteMtl
IMQuoteOpr
JobAsmbl
JobHead
JobMtl
JobOper
OpMaster
Part
PartMtl
PartOpr
QuoteAsm
QuoteDtl
QuoteMtl
QuoteOpr
--- In vantage@yahoogroups.com, "k_stump" <kristi.stump@...> wrote:
> Hi,
> Thanks !
> Kristi
bw2868bond
AnalysisCd
ECOMtl
ECOOpr
GlbPart
IMAnalysisCd
IMECOMtl
IMECOOpr
IMGlbPart
IMJobAsmbl
IMJobHead
IMJobMtl
IMJobOper
IMOpMaster
IMPart
IMPartMtl
IMPartOpr
IMQuoteAsm
IMQuoteDtl
IMQuoteMtl
IMQuoteOpr
JobAsmbl
JobHead
JobMtl
JobOper
OpMaster
Part
PartMtl
PartOpr
QuoteAsm
QuoteDtl
QuoteMtl
QuoteOpr
> Hi,
> Thanks !
> Kristi
I guess I 'cheated' then :o)
I opened the html schema of our db, clicked on part table and clicked on the field xref for the field.
Html schema was generated by the 'htmdict' progress app
> bw2868bond
> AnalysisCd
> ECOMtl
> ECOOpr
> GlbPart
> IMAnalysisCd
> IMECOMtl
> IMECOOpr
> IMGlbPart
> IMJobAsmbl
> IMJobHead
> IMJobMtl
> IMJobOper
> IMOpMaster
> IMPart
> IMPartMtl
> IMPartOpr
> IMQuoteAsm
> IMQuoteDtl
> IMQuoteMtl
> IMQuoteOpr
> JobAsmbl
> JobHead
> JobMtl
> JobOper
> OpMaster
> Part
> PartMtl
> PartOpr
> QuoteAsm
> QuoteDtl
> QuoteMtl
> QuoteOpr
> "k_stump" <kristi.stump@> wrote:
> > Hi,
> > Thanks !
> > Kristi
