Finite Scheduling
Ours is a 32 bit...Do you think it's the reason why it takes so long?
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> Ours is a 64 bit version of 2003
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of Richard
> Sent: Friday, November 19, 2010 10:29 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Finite Scheduling
> Your servers, Are they on 32 bits or 64 bits ?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Richard" <richard.larose@> wrote:
> > So, why it takes so long for us?
> > We have a good hardware setup...I think!
> > Do you already have this kind of results (4-5 days to run)
> > Regards,
> > Richard
> "Rob Bucek" <rbucek@> wrote:
> > > We are scheduling on 8.03.409a
> > > On average it schedules 4k -5k jobs
> > > Up to 7 levels deep (average is around 2 or 3)
> > > Typically 1 resource per operation
> > > About 70% of the resources are finitely scheduled (important note
> here:
> > > our finite horizon is only around 21 days, recommend you evaluate
> using
> > > this in some fashion)
> > > Server I think is a quad core zeon 3.2 gig with 16gb ram, vantage
> runs
> > > on raid ten 5 x 146gb drives
> > > Run time is around 2 hrs
> > > Rob Bucek
> > > FAX: (715)284-4084
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > > Of Chris Henzel
> > > Sent: Thursday, November 18, 2010 3:59 PM
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > Subject: RE: [Vantage] Re: Finite Scheduling
> > > Just for comparison we have around 2000 jobs with up to 10 indented
> > > levels. 80 resources, all finite. One resource per op.
> > > APS is installed but this is a recent addition to out E9
> implementation
> > > project (upgrade from 6.1) so most parts are not constrained and are
> > > purchased to stock other than a few jobs being used to test APS.
> > > Server is similar spec other than 2008 os and 24GB ram. E9.04.505C.
> > > Under 20 minutes to run global scheduling.
> > > Chris Henzel
> > > Epicor 9 Project Manager
> > > Tel: +44 (0)1582 436150
> > > Mob: 07836 314164
> > > This message contains confidential information and is intended only
> for
> > > the intended recipients. If you are not an intended recipient you
> should
> > > not disseminate, distribute or copy this email. Please notify the
> sender
> > > if you have received this email by mistake and delete it from your
> > > system.Email transmission cannot be guaranteed to be secure or
> > > error-free as information could be intercepted, corrupted, lost,
> > > destroyed, arrive late or incomplete, or contain viruses. The sender
> > > does not accept liability for any errors or omissions in the
> contents of
> > > this message, which arise as a result of email transmission.
> Registered
> > > Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton, LU1 3LD, England.
> Tel:
> > > +44 (0)1582 731144. Company No. 3450138.
> > > ________________________________
> <mailto:vantage%40yahoogroups.com> on
> > > behalf of Richard
> > > Sent: Thu 18/11/2010 19:35
> > > u
> > > 1. Number of jobs it schedules => approx. 4000 jobs
> > > 2. How many of your resources are finite => 20-24 Machines are
> finite /
> > > Human (500) Resources are infinite.
> > > 3. How many resources -ops => Most of the time, only one.
> > > 4. # of indented levels (average) => 0 to 36
> > > 5. Hardware run on?
> > > HP Proliant DL580 G5
> > > Windows 2003 Enterprise SP2
> > > RAM 16G
> > > Disk :
> > > 12x72G 15k SAS
> > > 4x146G 10k SAS
> > > 2 controlors :
> > > C : 273G (OS)
> > > E : 136G (AI)
> > > F : 273G (DB)
> > > G : 136G (BI)
> > > Processors :
> > > 4x Quad Xeon x7350 2.93Ghz
> > > 5. Constrained materials? => This function is not working on our
> version
> > > so we don't use it...
> > > 6. APS - capabilities used? => Yes, but when we use it, we put only
> 2/3
> > > resources cause this function is very limited.
> > > Thanks for your help!
> > > Regards,
> > > Richard
> > > <mailto:vantage%40yahoogroups.com> , "Rob Bucek" <rbucek@> wrote:
> > > > Need more information...
> > > > How many of your resources are finite/how many resources -ops
> > > > Hardware run on?
> > > > There are so many variables but answering some of these questions
> may
> > > > help us answer that. Just off the cuff it seems like an
> exceedingly
> > > > long time.
> > > > Rob Bucek
> > > > FAX: (715)284-4084
> > > <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> > > On Behalf
> > > > Of Richard
> > > > Sent: Thursday, November 18, 2010 12:39 PM
> > > > Subject: [Vantage] Finite Scheduling
> > > > Is it normal the GSP in finite mode takes 5-6 days.
> > > > It takes 5-6 days to run the entire process (firm/infirm jobs)
> > > > Regards,
> > > > Richard
> > > > [Non-text portions of this message have been removed]
We are running Vantage 5.2 322
We are testing some things with Finite Scheduling (Anyone using it out
there?)
We want to move our data over to 6.1 to do some testing but we want our
daily labor transactions to be able to be imported everyday without having
to restore a complete copy of 5.2. Can this be done?
there?)
Hey everyone,
Â
I have a problem with Finite scheduling and I think it is somewhere in a setup but I don't know where.
Â
The problem is that when we run MRP, Global Scheduling the Start Times on the some of the jobs are before Plant Opening. For instance Job 0000001 Start Time is 4:36AM and Due Time is 7:36AM. The plant doesn't start untill 7:00AM. The scheduler has to manuelly adjust each job to the correct start time and that means moving all of the other jobs as well.
Â
Any help would be appreciated.
Â
Jonathan LangÂ
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
Â
I think this is in your Production Calendar. If you open the calendar for
the resource, resource group, plant or company, you'll see the Default Hours
Per Day box. Set that to 24. Now if you want the resource available at 7:00
AM, you have to start checking the boxes starting with 7:00 AM. These
numbers on the boxes are the actual times and not number of hours. (I'm not
sure how to do the 1/2 hour start times though.)
This was mentioned at Perspectives this year and I think this will fix you
up. Give it a try and let us know if it works.
Mark W.
Mark, We were just discussinng the same thing about the 1/2 hour.
Â
Victor actually brought that up to me about the pruduction calander and thhe help is very misleading.
--- On Thu, 12/11/08, Mark Wonsil <mark_wonsil@...> wrote:
Subject: RE: [Vantage] Finite Scheduling
Date: Thursday, December 11, 2008, 1:30 PM
Mark W.
Defining your capacity hours via multiple shop calendars doesn't always prevent the problems described.
The Job Entry job scheduler has a nasty habit of scheduling the 1st OP to start at midnight. This is true when the RG or R is defined as infinite OR when the OP carries no cycle time (or set up time) (and is being scheduled into finite RG or R's).
I see scattered (random) similar results after the global runs nightly and retightens the deck of job-op load. (Example: Our machine shop is 100% finite and there are about 1500 2-22 OP jobs scheduled on any given day... About 1/3rd will have at least one OP starting at midight even though this is out of the 'workday' bounds set for that resource's calendar).
It's a bug (but fortunately not a drop dead critical one like others that exist).
Rob
Date: Thursday, December 11, 2008, 2:45 PM
Â
To: vantage@yahoogroups .com
Mark W.
Hi,
We are a custom job shop and we have some troubles to do finite schedule. Our difficulties is every single part have a different routing and every operation have a different ressource constraint. I want to know if somebody can finite schedule with Vantage and give us some help...
Best regards,
Richard
Hi Richard -
I use partially use Finite Schedule - We also have parts that have all kinds
of routings through all sorts of operations. What I found is that only a
few of our work centers are close enough to capacity to be considered
constraints. The others, (mostly saw, laser, forming, etc) have excess
capacity, so I let Vantage infinitely schedule those work centers. The
others, primarily weld and machining are the only ones I pay attention too.
Cuts down on the noise dramatically. Which version of Vantage are you on?
Elizabeth
_____
Richard
Sent: Monday, July 05, 2010 8:00 AM
Hi,
Best regards,
Richard
We too use a similar approach. We use finite scheduling on a couple resources that are machine constraints (Punching/Laser) and infinitely schedule all other resources.
We are running 9.04.506c and there is a bug in 9.04 where the finite resources will not schedule all operations finitely. Some of the operations get scheduled infinitely which results in a small overloading of the resource.
Troy
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Elizabeth
Sent: July-05-10 1:00 PM
Hi Richard -
Elizabeth
_____
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Richard
Hi,
Best regards,
Richard
Regards,
Richard
Hardware run on?
There are so many variables but answering some of these questions may
help us answer that. Just off the cuff it seems like an exceedingly
long time.
Rob Bucek
FAX: (715)284-4084
Of Richard
Regards,
Richard
2. How many of your resources are finite => 20-24 Machines are finite / Human (500) Resources are infinite.
5. Hardware run on?
RAM 16G
Disk :
12x72G 15k SAS
4x146G 10k SAS
2 controlors :
C : 273G (OS)
E : 136G (AI)
F : 273G (DB)
G : 136G (BI)
Processors :
5. Constrained materials? => This function is not working on our version so we don't use it...
6. APS - capabilities used? => Yes, but when we use it, we put only 2/3 resources cause this function is very limited.
Regards,
Richard
> Hardware run on?
> long time.
> Rob Bucek
> FAX: (715)284-4084
> Of Richard
> Regards,
> Richard
Just for comparison we have around 2000 jobs with up to 10 indented levels. 80 resources, all finite. One resource per op.
APS is installed but this is a recent addition to out E9 implementation project (upgrade from 6.1) so most parts are not constrained and are purchased to stock other than a few jobs being used to test APS.
Chris HenzelEpicor 9 Project ManagerTel: +44 (0)1582 436150Mob: 07836 314164
This message contains confidential information and is intended only for the intended recipients. If you are not an intended recipient you should not disseminate, distribute or copy this email. Please notify the sender if you have received this email by mistake and delete it from your system.Email transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender does not accept liability for any errors or omissions in the contents of this message, which arise as a result of email transmission. Registered Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton, LU1 3LD, England. Tel: +44 (0)1582 731144. Company No. 3450138.
u
5. Hardware run on?
RAM 16G
Disk :
12x72G 15k SAS
4x146G 10k SAS
2 controlors :
C : 273G (OS)
E : 136G (AI)
F : 273G (DB)
G : 136G (BI)
Processors :
Regards,
Richard
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob Bucek" <rbucek@...> wrote:
> Hardware run on?
> long time.
> Rob Bucek
> FAX: (715)284-4084
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
> Of Richard
> Regards,
> Richard
About 70% of the resources are finitely scheduled (important note here:
our finite horizon is only around 21 days, recommend you evaluate using
Server I think is a quad core zeon 3.2 gig with 16gb ram, vantage runs
Rob Bucek
FAX: (715)284-4084
Of Chris Henzel
Chris Henzel
Mob: 07836 314164
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> on
behalf of Richard
u
5. Hardware run on?
RAM 16G
Disk :
12x72G 15k SAS
4x146G 10k SAS
2 controlors :
C : 273G (OS)
E : 136G (AI)
F : 273G (DB)
G : 136G (BI)
Processors :
Regards,
Richard
> Hardware run on?
> long time.
> Rob Bucek
> FAX: (715)284-4084
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On Behalf
> Of Richard
> Regards,
> Richard
Regards,
Richard
> Rob Bucek
> FAX: (715)284-4084
> Of Chris Henzel
> Chris Henzel
> Mob: 07836 314164
> behalf of Richard
> u
> 5. Hardware run on?
> RAM 16G
> Disk :
> 12x72G 15k SAS
> 4x146G 10k SAS
> 2 controlors :
> C : 273G (OS)
> E : 136G (AI)
> F : 273G (DB)
> G : 136G (BI)
> Processors :
> Regards,
> Richard
> > Hardware run on?
> > long time.
> > Rob Bucek
> > FAX: (715)284-4084
> On Behalf
> > Of Richard
> > Regards,
> > Richard
> Regards,
> Richard
> > Rob Bucek
> > FAX: (715)284-4084
> > Of Chris Henzel
> > Chris Henzel
> > Mob: 07836 314164
> > behalf of Richard
> > u
> > 5. Hardware run on?
> > RAM 16G
> > Disk :
> > 12x72G 15k SAS
> > 4x146G 10k SAS
> > 2 controlors :
> > C : 273G (OS)
> > E : 136G (AI)
> > F : 273G (DB)
> > G : 136G (BI)
> > Processors :
> > Regards,
> > Richard
> > > Hardware run on?
> > > long time.
> > > Rob Bucek
> > > FAX: (715)284-4084
> > On Behalf
> > > Of Richard
> > > Regards,
> > > Richard
Rob Bucek
FAX: (715)284-4084
Of Richard
> Regards,
> Richard
here:
using
runs
> > Rob Bucek
> > FAX: (715)284-4084
Behalf
> > Of Chris Henzel
implementation
> > Chris Henzel
> > Mob: 07836 314164
for
should
sender
contents of
Registered
Tel:
> > behalf of Richard
> > u
finite /
> > 5. Hardware run on?
> > RAM 16G
> > Disk :
> > 12x72G 15k SAS
> > 4x146G 10k SAS
> > 2 controlors :
> > C : 273G (OS)
> > E : 136G (AI)
> > F : 273G (DB)
> > G : 136G (BI)
> > Processors :
version
2/3
> > Regards,
> > Richard
> > > Hardware run on?
may
exceedingly
> > > long time.
> > > Rob Bucek
> > > FAX: (715)284-4084
> > On Behalf
> > > Of Richard
> > > Regards,
> > > Richard
