Fire service connect with BPM
Problem solved. Actually needed to install the .NET 2.0 SP2 update.
Installed the service pack, rebooted, and the links worked. Thanks!
Of Brian W. Spolarich
Sent: Thursday, October 29, 2009 10:53 AM
Subject: RE: [Vantage] Fire service connect with BPM
You'll need to make sure that IIS is running and configured properly so
that the web service endpoints are configured and available so that
these URLs work (which are setup as part of the SC installation):
http://<hostname>/BPMIntegroupService/
http://<hostname>/WorkflowWebServices/
and although it doesn't matter to get things running, but is part of the
SC setup:
http://<hostname>/TaskMonitor/
where <hostname> is the hostname you've given to Vantage. Basically I
think Vantage builds these URLs to try to talk to Service Connect. Given
that you're getting a 404 Not Found, something in IIS isn't setup
properly. I could send the configs for those three virtual directories,
but basically you need to make sure you're using the right name to talk
to your web server, and that its configured properly.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
www.advancedphotonix.com
Behalf Of Matt Caldwell
Sent: Thursday, October 29, 2009 11:46 AM
I entered our server name, and my service connect username. The
password is blank. When I hit ok, I get the following message:
"Impossible to build workflows list: The request failed with HTTP status
404: Not Found."
Is there some setup I have to do on my service connect server to use
this??
Behalf
Of Charlie Wilson
Sent: Thursday, October 29, 2009 10:23 AM
It's asking for the name of your SC Server and a SC logon. The user and
PW
will be what ever you use to log into the admin console most likely
unless
you set up an account in SC just for BPM.
~Charlie
_____
Behalf Of
Matt Caldwell
Sent: Thursday, October 29, 2009 11:20 AM
Subject: [Vantage] Fire service connect with BPM
I am trying to setup a BPM to fire a service connect workflow, but I am
stumped.
I am at a "Logon to Service Connect" window. It asks for a server,
user, and password. What do I put there?
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Web Site: http://www.kerusso. <http://www.kerusso.com> com
stumped.
Matt Caldwell
KERUSSO
P.O. Box 32
Web Site: http://www.kerusso.com
\\servername <file:///\\servername>
username: admin
I don't use a password
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Matt Caldwell
stumped.
Matt Caldwell
KERUSSO
P.O. Box 32
It's asking for the name of your SC Server and a SC logon. The user and PW
will be what ever you use to log into the admin console most likely unless
~Charlie
_____
Matt Caldwell
stumped.
Matt Caldwell
KERUSSO
P.O. Box 32
Web Site: http://www.kerusso <http://www.kerusso.com> com
The hostname, username, and password of your Service Connect server. The default username is 'admin' with no password. Service Connect has its own authentication database.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Matt Caldwell
stumped.
Matt Caldwell
KERUSSO
P.O. Box 32
404: Not Found."
this??
Of Charlie Wilson
PW
unless
~Charlie
_____
Behalf Of
Matt Caldwell
stumped.
Matt Caldwell
KERUSSO
P.O. Box 32
You'll need to make sure that IIS is running and configured properly so that the web service endpoints are configured and available so that these URLs work (which are setup as part of the SC installation):
and although it doesn't matter to get things running, but is part of the SC setup:
where <hostname> is the hostname you've given to Vantage. Basically I think Vantage builds these URLs to try to talk to Service Connect. Given that you're getting a 404 Not Found, something in IIS isn't setup properly. I could send the configs for those three virtual directories, but basically you need to make sure you're using the right name to talk to your web server, and that its configured properly.
-bws
404: Not Found."
this??
Of Charlie Wilson
PW
unless
~Charlie
_____
Behalf Of
Matt Caldwell
stumped.
Matt Caldwell
KERUSSO
P.O. Box 32
I'm assuming your web services are available?
On the Service Connect server find:
C:\epicor\mfgsys803\WebServices\WS-Configuration (.Net 2.0 Edition).exe
Run it.
Look in the bottom left window pane in "Installed Items".
Ensure the service you are calling is installed.
If it already is, click on the check box "Reinstall All" and then
"Update Site". You need to do this after each Epicor SP install.
Vic
Of Matt Caldwell
404: Not Found."
this??
Of Charlie Wilson
PW
unless
~Charlie
_____
Behalf Of
Matt Caldwell
stumped.
Matt Caldwell
KERUSSO
P.O. Box 32
To add to what brian said which is all correct be sure that your
BPMIntegrationService is located in your default web site, it is
possible thru upgrading versions of service connect to end up with two
different web sites within IIS.
Also don't forget about your host file
C:\WINDOWS\system32\drivers\etc\hosts and have your IP address set for
scshost in your service connect server.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
SC setup:
-bws
Picometrix
bspolarich@...
404: Not Found."
this??
Behalf
Of Charlie Wilson
PW
unless
~Charlie
_____
Behalf Of
Matt Caldwell
stumped.
Matt Caldwell
KERUSSO
P.O. Box 32
