First Invoice of the day takes 5-12 mins to print. How can speed
Yes it is always just the first one.
I have not tried from the server yet but I will.
Where do you find the tuning guide that you are speaking of?
--- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@...> wrote:
> >five minutes
> 5 minutes does seem extreme.
> And it is always just the first one?
> If you log on at the server are the times the same?
> I wonder if this has anything to do with the way appservers trim?
> The progress explorer tool has a status display that might show you something.
> Have you reviewed the server settings or the tuning guide lately?
> Epicor tech might review your settings f you have support. They've been a big help to me with tuning.
> --- In vantage@yahoogroups.com, "jtannehill07" <jtannehill07@> wrote:
> > I tried changing the settings you suggested and it seemed to speed it up a little. But this morning I was going to hurry and beat the salesman and pull up a invoice to see if I could print the first one and get it out of the way so at least the customer would not have to wait and it took five minutes to even pull the invoice up when I went to click the invoice button to search and pull up the invoice it took forever to search then once I picked an invoice it took for ever to even load up before I could even think about printing and that would not have to do with crystal report I don't think. Any other ideas?
> > --- In vantage@yahoogroups.com, "Hatcher, John" <johnh@> wrote:
> > > I have found that a few adjustments to the Crystal report can make a
> > > huge difference in speed.
> > > 1. File / Page setup - make sure that the "No printer (optimize
> > > for screen display)" is checked. If this isn't checked, it can have a
> > > huge impact if you referenced a printer that is no longer available.
> > > You'll experience a timeout in the background that will delay the
> > > report.
> > > 2. Make sure that any images inserted into the document are
> > > optimized. Most reports I've seen should need to get bigger than 1Mb.
> > > 3. Double check that the "save data with report" is not checked.
> > > Hope one of these helps.
> > > John A. Hatcher
> > > Manager of IS
> > > Versa Products Co., Inc.
> > > (201) 843-2400 x4148
> > > (201) 843-2931 fax
report.
John A. Hatcher
Manager of IS
(201) 843-2931 fax
> report.
> John A. Hatcher
> Manager of IS
> (201) 843-2931 fax
>five minutes
> > report.
> > John A. Hatcher
> > Manager of IS
> > (201) 843-2931 fax
