Wonder if anyone can tell me why switching focus is not working the same between native panels and those added via the sheet wizard?
I have been able to consistently switch the focus to a standard panel thru code right without doing anything extra after the form loads.
Sheet wizard panels on the other hand are requiring me to manually selected that custom sheet at least once (EpiDockManagerPanel) before I can get the focus to start switching via code.
thanks in advance
private void SetFocus_SheetWizardSheet()
/// Works ONLY AFTER I have previously switched to the custom sheet manually at least once
/// Sheet Wizard panel
Ice.Lib.Framework.EpiDockManagerPanel rm = (Ice.Lib.Framework.EpiDockManagerPanel)csm.GetNativeControlReference(“05109c6a-662b-4927-a635-5b1220f8a972”);
rm.Focus();
/// TextBox
EpiTextBox txtMtlMtlType = (EpiTextBox)csm.GetNativeControlReference(“f77b0846-34f1-4988-8bea-5cd1e76b0d77”);
txtMtlMtlType.Focus();
private void SetFocus_StandardPanel()
// This seems to work consistently right after loading the form
Erp.UI.App.GLControlPanels.EntityGLCPanel gl = (Erp.UI.App.GLControlPanels.EntityGLCPanel)csm.GetNativeControlReference(“dcc39723-184f-4719-afa5-4aeed95c131b”);
gl.Focus();
// TextBox
EpiTextBox txtGLControlType = (EpiTextBox)csm.GetNativeControlReference(“7b658a83-6d71-465e-8bb3-b34d67928dba”);
txtGLControlType.Focus();
