Is it possible to change the forecast date in Epicor?
Regards,
Dennis
Regards,
Dennis
You have to delete the line to change a forecast date. You can change the quantity, but not the date in the Forecast Entry screen.
As an alternative, you can export/import a forecast with a .csv - in case you have to make a lot of changes.
Thank you for your response. The information you have provided will help me to proceed with the next steps. But do you known the reason why it is not possible to change a forecast date in the Forecast Entry screen?
I did not write the software. You’ll have to ask that person.
Do you mean Epicor?
