Force Form Refresh on Save
Works perfectly. Thanks!
Of vicdrecchio
Sent: Friday, January 07, 2011 12:23 PM
Subject: [Vantage] Re: Force Form Refresh on Save
I use this on my Labor Entry to force a refresh upon Update. Works
great. Just a simple oTrans.Refresh() on the after-adapter method.
Private Sub oTrans_laborAdapter_AfterAdapterMethod(ByVal sender
As object, ByVal args As AfterAdapterMethodArgs) Handles
oTrans_laborAdapter.AfterAdapterMethod
'// ** Argument Properties and Uses **
'// args.MethodName
'Add Event Handler Code
'MessageBox.Show(args.MethodName) ' use this to find
method
Select Case args.MethodName
Case "Update"
oTrans.Refresh()
Case Else
End Select
End Sub
--- In vantage@yahoogroups.com, "Brian W. Spolarich" <bspolarich@...>
wrote:
> Ping on this in case anyone who does client customization cares. :-)
Behalf
> Of Brian W. Spolarich
> Sent: Thursday, January 06, 2011 12:04 PM
> Subject: [Vantage] Force Form Refresh on Save
> Is there an easy way to force a form to refresh after every save?
> I have a RowRule on the Labor Entry screen to show an error if
> DspPayHours and TotLbrHrs aren't the same (or whatever). However if I
> make a change and save it, the rowrule doesn't fire unless I refresh.
> Ideally I'd just line to make sure that after the Save button is
> clicked the form saves but the rowrules are invoked.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix
> Picometrix
> bspolarich@...
> <mailto:bspolarich@...> ~ 734-864-5618 ~
> www.advancedphotonix.com <http://www.advancedphotonix.com>
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@...
-bws
Picometrix
bspolarich@...
I second you. I also would love to know how to do this.
Ephraim Feldman
Programmer / Analyst
Axis Lighting
Sender: vantage@yahoogroups.com
Date: Fri, 7 Jan 2011 11:35:05
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: RE: [Vantage] Force Form Refresh on Save
-bws
Picometrix
bspolarich@...
I use this on my Labor Entry to force a refresh upon Update. Works great. Just a simple oTrans.Refresh() on the after-adapter method.
Private Sub oTrans_laborAdapter_AfterAdapterMethod(ByVal sender As object, ByVal args As AfterAdapterMethodArgs) Handles oTrans_laborAdapter.AfterAdapterMethod
'// args.MethodName
'MessageBox.Show(args.MethodName) ' use this to find method
Case "Update"
oTrans.Refresh()
Case Else
End Select
End Sub
> -bws
> Picometrix
> bspolarich@...
Just guessing out loud here.....
After adapter method
Case "Update"
oTrans.Refresh()
Case Else
End Select
> Ephraim Feldman
> Axis Lighting
> From: "Brian W. Spolarich" <bspolarich@...>
> -bws
> Picometrix
> bspolarich@...
Thanks, Vic. That's exactly the kind of thing I was expecting, but
its so difficult to know how to leverage this object model and the
specifics of it if you don't do this very often.
I'll try this later today and verify it works for me.
-brian
Of vicdrecchio
'// args.MethodName
method
Case "Update"
oTrans.Refresh()
Case Else
End Select
End Sub
Behalf
> -bws
> Picometrix
> bspolarich@...
