Force project number when using specific GL account on AP Invoices
Hi,
I’d like to know if we are able to force the in input of a related “project number” when using our “sales commissions” GL account on AP Invoices / Payments.
My main goal here is to have a proper way to make sure that we can properly track which commissions were paid to specific salesperson.
If you have a better solution for my need, I’m open to suggestions.
Thanks!
If a supplier is working only with one project then you can define and map the GL mapping at supplier level. Otherwise, you need to change the Posting Engine for it.
KR
I have modified the Posting Engine for both AP and AR to use the project number, and it’s been working well for our business needs. You might be able to use a similar approach for your setup as well.
You build that bot?
