How does that effect costing? When you do track multiple UOMs the actual
ABBR will be the same CS but the conversion factor would be different how
does that work?
Joshua Giese
Chief Technical Officer
920.437.6400 Ext. 337
*Do not follow where the path may lead. Go instead where there is no path
and leave a trail - Harold R. McAlindon*
Kevin Simon
Sent: Friday, January 06, 2012 10:27 PM
Subject: RE: [Vantage] Force UOM Change
You can do a quantity adjustment to adjust the quantity out of the old UOM,
then a quantity adjustment back in with the new UOM. You'll need to have
the UOM's set up, and you'll need to ensure the "track multiple UOM's" flag
is set to TRUE on the part master.
Behalf Of
Anon
Sent: Thursday, January 05, 2012 10:11 AM
Subject: [Vantage] Force UOM Change
Any way to force a UOM change after transactions have been made?
We have a part specific unit of measure for all of our parts that is how
many EA are in a CS. CS being case which could be any number of eaches. We
have a goofed stock part and don't want to change the stock part number.
There has to be a way to change these in some way isn't there?
does that work?
Joshua Giese
Kevin Simon
Behalf Of
Anon
