Format Numeric Field in Grid
Works like a charm. Thank you and my users thank you as well.
Of laidig.systems
Sent: Monday, June 09, 2008 7:11 AM
Subject: [Vantage] Re: Format Numeric Field in Grid
I had this same problem. It is a pain that you set all the formating
for the grid in customizations but then nothing seems to save. You
can put this code in the Load Event and it should do the trick. Hope
this helps.
'----Get Control of the Vantage Grid Item
Dim eugMileStones As EpiUltraGrid =
Ctype(csm.GetNativeControlReference("f3c57ba9-bc37-48f7-951b-d7c1c266ed7
0"),EpiUltraGrid)
'Set Formating for the Grid Field
eugMileStones.DisplayLayout.Bands(0).Columns("Number01").Format =
"###,##0.00"
"Charles Carden" <ccarden@...> wrote:
> I have been attempting to assign a format and input mask to a UD field
> in a grid list. I have discovered it will work as long as I am in the
> customization but once I exit and come back to the program the
> formatting is lost. It appears to me those options are not saved as
> part of the customization. At least I cannot find them in
customization
> maintenance.
> I was hoping someone has a code snippet they would share where this
has
> been done. My users would really like to see a sales order number in
> the format of 1234567 instead of 1,234,567.00. I don't blame them
> either.
> Thanks in advance,
> Charles Carden
> Manager, MIS
> Manitex, Inc.
> Phone: 512-942-3086
> Fax: 512-942-3089
> DISCLAIMER:
> This e-mail, including attachments, may include confidential and/or
> proprietary information, and may be used only by the person or entity
to
> which it is addressed. If the reader of this e-mail is not the
intended
> recipient or his or her authorized agent, the reader is hereby
notified
> that any dissemination, distribution or copying of this e-mail is
> prohibited. If you have received this e-mail in error, please notify
the
> sender by replying to this message and delete this e-mail immediately.
Charles Carden
Manager, MIS
Manitex, Inc.
Phone: 512-942-3086
Fax: 512-942-3089
DISCLAIMER:
proprietary information, and may be used only by the person or entity to
which it is addressed. If the reader of this e-mail is not the intended
recipient or his or her authorized agent, the reader is hereby notified
prohibited. If you have received this e-mail in error, please notify the
part of the customization. At least I cannot find them in customization
maintenance.
I was hoping someone has a code snippet they would share where this has
either.
Thanks in advance,
Charles Carden
Manager, MIS
Manitex, Inc.
Phone: 512-942-3086
Fax: 512-942-3089
DISCLAIMER:
this helps.
Ctype(csm.GetNativeControlReference("f3c57ba9-bc37-48f7-951b-d7c1c266ed70"),EpiUltraGrid)
"###,##0.00"
> maintenance.
> either.
> Thanks in advance,
> Charles Carden
> Manager, MIS
> Manitex, Inc.
> Phone: 512-942-3086
> Fax: 512-942-3089
> DISCLAIMER:
