Worked perfectly. Thanks so much
--- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@...> wrote:
> Carl,
> Add the following call in the InitializeCustomCode() section:
> SetExtendedProps()
> Then, add the following sub:
> Private Sub SetExtendedProps()
> Dim edv As EpiDataView = CType(oTrans.EpiDataViews("Part"),
> EpiDataView)
> edv.dataView.Table.Columns("Number01").ExtendedProperties("Format")
> = ">>>9"
> End Sub
> Hope that helps,
> Kevin Simon
> SimsTrak Consulting
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> CarlH
> Sent: Monday, July 18, 2011 3:37 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Formatting a UD field in an Form
> Can someobdy help me out with the code necessary to set the format of a UD
> numeric field to one without decimals, i.e. Format: <<<9. My field is the
> Number01 field from the Part table and form
> I assume that this can be handled as a Form Load event but I'm not clear
> what the code is to change this.
> What goes here?
> Private Sub UserAccountForm_Load(ByVal sender As object, ByVal args As
> EventArgs) Handles UserAccountForm.Load
> '// Add Event Handler Code
> End Sub
> Thanks
