# Formatting Code block
**URL:** <https://www.epiusers.help/t/formatting-code-block/52608>\
**Category:** FAQ\
**Created:** [February 14, 2019, 5:21pm UTC](https://www.epiusers.help/t/formatting-code-block/52608 "2019-02-14T17:21:21Z")\
**Posts on this page:** 1\
**Showing post:** 6
<div class="post-metadata">
**Author:** ![josecgomez](https://www.epiusers.help/user_avatar/www.epiusers.help/josecgomez/32/55731_2.png) [@josecgomez](https://www.epiusers.help/u/josecgomez)\
**Post date:** [February 27, 2019, 7:46pm UTC](https://www.epiusers.help/t/formatting-code-block/52608/6 "2019-02-27T19:46:05Z")
</div>
Hey Guys, also check out the summarize feature. This is especially handy when posted a long error detail or trace or something. Details that need to be there, but can hinder the flow of the conversation.
It works like this
first, paste in your text, then highlight it. Click the gear icon, and choose hide details.
 ![image.png](https://epiusers.help/uploads/default/original/2X/d/d5ef1fc1514ea0275d55f877455db29a278e2c29.png)
After you do that, you will see your text bracketed by this code. You can change the “summary” text to whatever you think would be helpful
 ![image.png](https://epiusers.help/uploads/default/original/2X/e/e06b3ec8b7204f69a29d82782f7455bcf78bc44a.png)
Then when you post, this is what it will look like. So if you have a ton of text, it really condenses the flow so you can keep the conversation flowing. This really helps when you are trying to return back the earlier in the conversation to re-read some details.
 ![summary.gif](https://epiusers.help/uploads/default/original/2X/1/1100c56ceba565548c873dd0d751d6d9f0597c09.gif)
_[View the full topic](https://www.epiusers.help/t/formatting-code-block/52608)._
