Forms Blank Title 59962
The UI utilizes EpiDataView which are often based off of TempTables,
these are generated automatically pulling in data from different areas.
Hence not all fields exist in the table, some are also calculated, there
is also another table called Patchfld which stores additional fields
Epicor add prior to a schema change
Hope this helps
Of Hernandez, Dolores
Sent: 17 October 2007 18:37
Subject: [Vantage] Forms
I have noticed that on the forms (in this case, the AR form) within
Vantage, some fields are not in the database. For instance, on the AR
form, I see a field called "InvcHead.Cursymb", but when I look in the
Data dictionary, it is not there. If anyone could enlighten me here,
that would be great. Thanks,
__________________________________________________
Dolores Hernandez
Software Analyst
Energy Cranes, LLC
6707 Northwind Drive
Houston, Texas 77041
Tel: 713-896-5178
Fax: 713-896-5142
Email: dhernandez@...
<mailto:dhernandez%40energycranes.com>
Dolores Hernandez
Software Analyst
Energy Cranes, LLC
Tel: 713-896-5178
Fax: 713-896-5142
