Full instance restore on 8.x
Take the scenario where we have a fourth db not part of the
original install and are installing this to a new system.
We now need a fourth app server - not provided by the
original install.
Im not sure if you can/cannot restore one db instance to
another machine and if those ports are common or not since
I think some of the ports are stored in the db as well as
the config files. During a test I restored one db to
another instance (test to pilot) - and it didn't work error
msg received shows its looking to a different port than the
app server is running on.
Imagine if I called up Vantage and said "we need a new
database called live3 restored from an existing backup".
That full process is what's needed.
On Tue, 10 Oct 2006 07:01:26 -0400
"Todd Hofert" <todd@...> wrote:
> Why wouldn't you use the installation media to install
> Progress and
> Vantage, then use prorest to restore your back-up. That
> process would
> take half a day max. Installation creates all of your
> appservers,
> containers etc.
> Todd
> From: vantage@yahoogroups.com
> [mailto:vantage@yahoogroups.com] On Behalf
> Of Adam Tuliper
> Sent: Monday, October 09, 2006 9:21 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Re: Full instance restore on 8.x
> Just for a straight restore, yes, not however if it is a
> new instance
> being restored from a backup to a non-default instance
> name or to a new
> instance.
> That procedure below I believe simply expands the files,
> but does
> nothing with integrating into progress (db won't appear
> in explorer) and
> creating appservers, thats what I need to do.
> Take an instance named "prod1" (for ex) and create
> everything from there
> on out after doing prorest.....
> From: Todd Hofert
> <mailto:vantage%40yahoogroups.com>
> Sent: Monday, October 09, 2006 5:22 PM
> Subject: RE: [Vantage] Re: Full instance restore on 8.x
> Restoring a db back-up is very straight forward if you
> are talking about
> taking a backup and restoring it to a server with the
> same version
> Progress and Vantage installed on it.
> Open Proenv, type prompt and hit enter.
> Change directories to the directory where the target db
> is/will be
> stored.
> type prorest mfgsys backup.1
> where mfgsys is then name of the target database and
> backup.1 is the
> name of your db backup.
> it enter and wait until it says it is complete.
> Log in and go.
> Todd
> <mailto:vantage%40yahoogroups.com> on
> behalf of adamtuliper
> Sent: Mon 10/9/2006 7:56 PM
> Subject: [Vantage] Re: Full instance restore on 8.x
> Ya, I didn't see anything in Vantage - didn't think there
> would be as
> its a catch 22 since essentially Im looking for the
> procedures that
> the Vantage install team would follow to bring up a db
> from a backup
> file into full capability. In order to have something in
> Vantage it
> would prob require vantage to already be up and running.
> I'm sure
> I'll figure it out.. just would prefer to know the
> 'proper' procedure
> before I start hacking things together especially if
> totally
> unnecessary : )
> Im just in planning phase now and Vantage isn't to pilot
> yet, but I
> plan on doing offsite backups for vantage as well as
> running a
> virtual server instance all ready to go for production
> environment in
> case of a 'disaster'. So in DR, I'll create a new
> instance, restore
> to it. So offsite backups will contain virtual server
> backup file and
> vantage db where virtual server instance is setup with an
> old copy of
> the db and I can just restore a newer one and be good to
> go.
> --- In vantage@yahoogroups.com
> <mailto:vantage%40yahoogroups.com> , RSN <rsnsfi@...>
> wrote:
> > Nothing in Vantage that I know of yet. Would be useful
> for us as
> well.However, curious if you do a full server backup
> weekly, monthly
> and cycle tapes off-site?.
> > adamtuliper <amt@...> wrote:
> > Is there any documentation around on the specific steps
> in vantage
> > 8.x to restore a database backup to a full operating
> instance?
> > seems the steps may be the following but Im not sure,
> and hence
> want
> > to see if theres a doc available.
> > 1. restore db - have that done.
> > 2. create db in progress explorer (ok, I can follow the
> format for
> an
> > existing db)
> > 3. create app server instances (I can copy - but want
> to make sure
> > this is done correctly)
> > 4. create config file to point to new ports
> > 5. point db to proper app server ports?
> > The assumption needs to be in terms of disaster
> recovery:
> > 1. a db backup is available - use it.
> > 2. software install is available - install
> > 3. make everything work
> > Thanks!
> > Adam
> > Stay in the know. Pulse on the new Yahoo.com. Check it
> out.
> This e-mail and any attachments may contain confidential
> and privileged
> information. If you are not the intended recipient,
> please notify the
> sender immediately by return e-mail, delete this e-mail
> and destroy any
> copies. Any dissemination or use of this information by a
> person other
> than the intended recipient is unauthorized and may be
> illegal.
> and privileged
> please notify the
> and destroy any
> person other
> illegal.
Web mail provided by NuNet, Inc. The Premier National provider.
http://www.nni.com/
Is there any documentation around on the specific steps in vantage
8.x to restore a database backup to a full operating instance?
seems the steps may be the following but Im not sure, and hence want
2. create db in progress explorer (ok, I can follow the format for an
existing db)
3. create app server instances (I can copy - but want to make sure
The assumption needs to be in terms of disaster recovery:
Thanks!
Adam
Nothing in Vantage that I know of yet. Would be useful for us as well.However, curious if you do a full server backup weekly, monthly and cycle tapes off-site?.
existing db)
Thanks!
Adam
Stay in the know. Pulse on the new Yahoo.com. Check it out.
Ya, I didn't see anything in Vantage - didn't think there would be as
its a catch 22 since essentially Im looking for the procedures that
the Vantage install team would follow to bring up a db from a backup
file into full capability. In order to have something in Vantage it
would prob require vantage to already be up and running. I'm sure
I'll figure it out.. just would prefer to know the 'proper' procedure
before I start hacking things together especially if totally
unnecessary : )
Im just in planning phase now and Vantage isn't to pilot yet, but I
plan on doing offsite backups for vantage as well as running a
virtual server instance all ready to go for production environment in
case of a 'disaster'. So in DR, I'll create a new instance, restore
to it. So offsite backups will contain virtual server backup file and
vantage db where virtual server instance is setup with an old copy of
the db and I can just restore a newer one and be good to go.
in vantage
want
an
> existing db)
> Thanks!
> Adam
Restoring a db back-up is very straight forward if you are talking about taking a backup and restoring it to a server with the same version Progress and Vantage installed on it.
Change directories to the directory where the target db is/will be stored.
where mfgsys is then name of the target database and backup.1 is the name of your db backup.
Log in and go.
Todd
From: vantage@yahoogroups.com on behalf of adamtuliper
unnecessary : )
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , RSN <rsnsfi@...> wrote:
in vantage
want
an
> existing db)
> Thanks!
> Adam
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
Just for a straight restore, yes, not however if it is a new instance being restored from a backup to a non-default instance name or to a new instance.
That procedure below I believe simply expands the files, but does nothing with integrating into progress (db won't appear in explorer) and creating appservers, thats what I need to do.
Take an instance named "prod1" (for ex) and create everything from there on out after doing prorest.....
Log in and go.
Todd
unnecessary : )
in vantage
want
an
> existing db)
> Thanks!
> Adam
How about just restoring the ubroker.properties file that defines all
the appservers etc
Of Adam Tuliper
Sent: 10 October 2006 02:21
instance.
stored.
Log in and go.
Todd
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> on
unnecessary : )
in vantage
want
an
> existing db)
> Thanks!
> Adam
Yes.. that would work if I was doing a full restore.. but Im not looking for that (although I do appreciate the suggestion!)
Restoring doesnt tell me what the requirements are to understand how to bring an entire working instance up from scratch and how everything fits together. Im a developer, and as such like extremely technical information.... helps me to understand the whole process more. If we have a custom instance that I want to bring up on a development machine to play with (in addition to the others.. or bring it up as a new instance name), or a disaster recovery site, or an additional database at an office on the opposite coast, I want to understand the full procedure - all of the requirements and procedures to bring everything up.. etc. Also helps me to understand to know which component may be failing in any given circumstance (a month of working on the system and although I like it.. still receive several errors every day).
Sent: Monday, October 09, 2006 6:25 PM
the appservers etc
Of Adam Tuliper
instance.
stored.
Log in and go.
Todd
unnecessary : )
in vantage
want
an
> existing db)
> Thanks!
> Adam
You want to know how to take a working database and make it work on
another machine?
just trying to understand the question.....
> From: Stephen Edginton
all
> the appservers etc
Behalf
> Of Adam Tuliper
instance
a new
> instance.
explorer) and
from there
> From: Todd Hofert
talking about
> stored.
the
> Log in and go.
> Todd
on
be as
that
backup
it
procedure
> unnecessary : )
I
environment in
restore
and
copy of
as
monthly
> in vantage
> want
for
> an
> > existing db)
sure
> > Thanks!
> > Adam
privileged
the
destroy any
other
Why wouldn't you use the installation media to install Progress and
Vantage, then use prorest to restore your back-up. That process would
take half a day max. Installation creates all of your appservers,
containers etc.
Todd
Of Adam Tuliper
instance.
stored.
Log in and go.
Todd
unnecessary : )
in vantage
want
an
> existing db)
> Thanks!
> Adam
