Functionality of Tab and DEL key in BAQ designer
  1. When creating table relationships in a BAQ (or othe forms with the similar grid), and you are at the last column of the last row in the grid, pressing Tab adds a new row, and sets focus to the first column. (many grids in other forms actually do this)
  2. In BAQ designer, when editing a a display columns label, pressing the DEL key deletes the row. If wit was a calculated field it is gone, and will have to be recreated.
BONUS REQUEST!!!
In the BAQ designer Table Criteria, when you select the type from the drop-down list, automatically activate the highlighted item. Right now it takes 4 clicks just to get to the point where I can start to define the criteria.
  1. The first selects the field (but doesn’t make the drop-down list show)
  2. The second click makes the drop down list appear
  3. The third click is used to select which drop down item to use
  4. The fourth is to actually click the link to launch the specific entry window.
I’M NOT MADE OF MOUSE CLICKS!!! :wink:
