FW: Call # 1855745ESC - CRM Customer does not show up on Custome
I edit the server file prior to releasing the patch for the client updates.
When the clients update they all are set to the new value.
Steve
Sent: October 15, 2009 8:03 AM
Subject: RE: [Vantage] Re: FW: Call # 1855745ESC - CRM Customer does not
show up on Customer Search
It actually used to be 1000.
My guess is performance?
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of advantage@wcoil. <mailto:advantage%40wcoil.com> com
Sent: Thursday, October 15, 2009 5:45 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: Re: [Vantage] Re: FW: Call # 1855745ESC - CRM Customer does not
Why doesn't epicor just change it to 1000 and be done with it. It seems like
a decent amount of records without overload. 100 is too small.
Sent from my Verizon Wireless BlackBerry
From: "Charlie Wilson" <foamdesigncsw@ <mailto:foamdesigncsw%40yahoo.com>
yahoo.com<mailto:foamdesigncsw%40yahoo.com>>
Date: Thu, 15 Oct 2009 06:33:08
To: <vantage@yahoogroups <mailto:vantage%40yahoogroups.com>
.com<mailto:vantage%40yahoogroups.com>>
Please not that if you make a custom Config file and point your client to
use it you will need update the <Version value="8.03.407" /> line each time
you update or your client will go through the auto update process each time
it loads. It uses this line to determine what version the client is if it
doesn't match what's on the server it goes into auto update.
~Charlie
_____
.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups
<mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]
On Behalf Of
Steve_E
Sent: Wednesday, October 14, 2009 4:12 PM
Keep in mind that you will have to do this every patch unless you copy the
file to a new name edit. You will then have point the shortcut to the new
file by adding /config=xxx.mfgsys to the path. Replace the xxx with the
newly saved path name.
Steve
<mailto:blake.clemens%40d-m-c.com> d-m-c.com]
Sent: October 14, 2009 3:07 PM
You are welcome. Glad I could help.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Behalf
Of Vic Drecchio
Sent: Wednesday, October 14, 2009 4:06 PM
Blake, it worked for me, By the way, yesterday.
(in case I forgot to say THANKS!)
<mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Blake Clemens
Sent: Wednesday, October 14, 2009 3:56 PM
On the user PCs, go to the c:\client803\client\config folder. Edit the
mfgsys.default file using Notepad. Find this entry
<DefaultSearchPageSize value="100" /> Change the 100 to 1000 or
whatever you want the returned search about to be. Save the file.
That's it, problem solved.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Virginia
Sent: Wednesday, October 14, 2009 3:52 PM
Subject: [Vantage] Re: FW: Call # 1855745ESC - CRM Customer does not
Please share. My salesmen will be forever grateful.
Virginia Joseph
Director, IT & Strategic Initiatives
Deep Hole Specialists
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
<mailto:vantage%40yahoogroups.com> ,
"Blake Clemens" <blake.clemens@...> wrote:
> I have a work around... who needs one?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> Sent: Tuesday, October 13, 2009 6:27 PM
> Subject: RE: [Vantage] FW: Call # 1855745ESC - CRM Customer does not
<mailto:vantage%40yahoogroups.com> wrote:
> > On 408B SQL we have a bug where one searches for a Customer
> > and they are not all displayed until you hit the Next100
> > button at the bottom
> > The SCR is below and due to be resolved in .409. Anyone have
> > a work-around by chance?
> When we were still on Vantage, we noticed that clicking the Binoculars
> gave
> the old behavior but clicking on the Customer Number button to search
> gave
> the result you shared.
> They said it was "by design" and that other companies were clamoring
for
> this kind of behavior. I asked for their address...
> By the sound of it, it was probably requested by the guys who wrote
the
> search for Yahoo! Groups...
http://groups. <http://groups.
<http://groups. <http://groups.yahoo.com/group/vantage/files/>
yahoo.com/group/vantage/files/.>
<http://groups. <http://groups.yahoo.com/group/vantage/messages>
<http://groups. <http://groups.yahoo.com/group/vantage/linksYahoo>
yahoo.com/group/vantage/linksYahoo! Groups Links
On 408B SQL we have a bug where one searches for a Customer and they are not all displayed until you hit the Next100 button at the bottom
The SCR is below and due to be resolved in .409. Anyone have a work-around by chance?
Sent: Tuesday, October 13, 2009 11:52 AM
To: Vic Drecchio
Subject: Call # 1855745ESC - CRM Customer does not show up on Customer Search
SCR 59147 will solve this problem in version 8.03.409, which is planned for release at the end of October.
The workaround would be to click on Next 100 button until the customer shows up or create a Named Search to have Return All Rows option set by default.
Regards.
Ricardo Valdés
Vista/Vantage Production Support
www.epicor.com
Vantage/Vista: (800)-426-8468
Epicor 9: (888)-374-2679
E-Mail: RValdes@...
Worldwide Headquarters 18200 Von Karman, Irvine CA 92612 USA
<http://perspectives.epicor.com/>
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses. Any views and/or opinions expressed in this e-mail are of the author only and do not represent the views of Epicor Software Corporation or any other company within its group.
This message has been scanned for malware by Websense. www.websense.com <http://www.websense.com/>
You can modify that in your default.mfgsys file. It's located in c:\client803\client\config\ you want to change this setting... <DefaultSearchPageSize value="100" /> change it to 1,000 or what ever you need.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Tuesday, October 13, 2009 11:56 AM
Subject: [Vantage] FW: Call # 1855745ESC - CRM Customer does not show up on Customer Search
From: Ricardo Valdes [mailto:RValdes@... <mailto:RValdes%40epicor.com> ]
To: Vic Drecchio
Regards.
Ricardo Valdés
www.epicor.com
E-Mail: RValdes@... <mailto:RValdes%40epicor.com>
When we were still on Vantage, we noticed that clicking the Binoculars gave
the old behavior but clicking on the Customer Number button to search gave
They said it was "by design" and that other companies were clamoring for
By the sound of it, it was probably requested by the guys who wrote the
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Mark Wonsil
gave
gave
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of Mark Wonsil
> gave
> gave
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Vic Drecchio
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
Steve
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Vic Drecchio
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
http://groups. <http://groups.yahoo.com/group/vantage/files/.>
~Charlie
_____
Steve_E
Steve
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Vic Drecchio
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
Why doesn't epicor just change it to 1000 and be done with it. It seems like a decent amount of records without overload. 100 is too small.
To: <vantage@yahoogroups.com>
Subject: RE: [Vantage] Re: FW: Call # 1855745ESC - CRM Customer does not show up on Customer Search
~Charlie
_____
Steve_E
Steve
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Vic Drecchio
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
Cuz they avoid updating the config file because it would bring havoc to a
lot of their customers cuz everyone has hacked the config files.
~Charlie
_____
advantage@...
Sent: Thursday, October 15, 2009 7:45 AM
yahoo.com>
To: <vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com>
~Charlie
_____
Behalf Of
Steve_E
Steve
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Vic Drecchio
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of advantage@...
Subject: Re: [Vantage] Re: FW: Call # 1855745ESC - CRM Customer does not show up on Customer Search
From: "Charlie Wilson" <foamdesigncsw@...<mailto:foamdesigncsw%40yahoo.com>>
To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
~Charlie
_____
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Steve_E
Steve
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Vic Drecchio
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
I think it was one of the things they changed when upgrading to version
400 to improve performance.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Ken Williams
Sent: Thursday, October 15, 2009 9:03 AM
Behalf Of advantage@... <mailto:advantage%40wcoil.com>
<mailto:foamdesigncsw%40yahoo.com> <mailto:foamdesigncsw%40yahoo.com>>
To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
to
time
time
it
~Charlie
_____
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf Of
Steve_E
the
new
Steve
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Vic Drecchio
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Virginia
Virginia Joseph
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of Mark Wonsil
> gave
> gave
for
the
