Nigel,
But how will you get the data back in to Vantage? I didn't think
there was an import?
Denise
Denise
--- In vantage@egroups.com, Nigel Roberts <nigelr@m...> wrote:
> Almost forgot - the problem with changing the costing method for a
part
> of course is that there has to be zero on-hand quantity - luckily
we can
> cope with this as we're implementing inventory at this time also.
> > -----Original Message-----
> > From: Nigel Roberts
> > Sent: 10 January 2001 16:48
> > To: 'Vantage User List (US)'
> > Subject: Chainging Costing Methods
> > I'm currently trying to do this by exporting a report of part
numbers
> > which now use average costing (for instance) and then using Macro
> > Express to run through these parts and change the costing method
to
> > standard. I'm not entirely sure it's going to be a robust
solution but
> > at least it's only needed once!
> > Nigel Roberts
> > MC Sheet Metal
> > Wales, UK
> > Date: Wed, 10 Jan 2001 14:10:55 -0000
> > From: "Denise Brown" <dbrown@f...>
> > Subject: Changing Costing Methods
> > We're running Vantage 4.0, and currently have our purchased parts
set
> > up using Average costing and everything else is set to Standard
> > costing. We want to change to using Standard for everything.
I'm
> > told that to accomplish this, we'll need to go into each part
> > individually that we want to change, and zero out the quantities,
> > change the costing method, and then add the quantity back in.
Does
> > anyone know of an easier way to do this?
> > Thanks!
> > Denise Brown
