Fw: Customization controls properties
Ephraim Feldman
Date: Thu, 27 May 2010 16:34:35
To: Brychan Williams<brychanwilliams@...>
Subject: Re: [Vantage] Re: Customization controls properties
No sorry had no luck and for now I gave up and got busy in other things.
But if anyone can point us in the right direction I would greatly appreciate.
Ephraim Feldman
Date: Thu, 27 May 2010 16:27:57
To: <effgroups@...>
Subject: Fw: [Vantage] Re: Customization controls properties
Hi,
I am looking to do the same thing. Just wondering if you had any success on this and would be willing to share it ?
Regards
Â
----- Forwarded Message ----
Sent: Thu, 13 May, 2010 2:19:00
Â
I tried searching there for a while but I came up empty handed.
If you would be so kind to point me more specific where I have to look I would appreciate.
Ephraim Feldman
Date: Wed, 12 May 2010 20:47:10
To: <vantage@yahoogroups.com>
Subject: [Vantage] Re: Customization controls properties
The Epicor controls are based on Infragistics controls to a large degree though Epicor does remove or ignores some of the capability. If you search Infragistics site for similar named controls you will find most of the properties. For example you might search for "grid" or "combobox" which will lead to what Infragistics calls the control. As I mentioned not all of the properties are valid for Epicor's version of the control. Also under it all the controls have a basis as a .net control so the epicombo has pretty much the base properties of a standard combo box so the Microsoft website can help you with doing simple things. Trivial example but if you wanted to see how the width property worked the explanation at Microsoft will suffice. And while the Infragistics and Epicor version of the combo have some cool/powerful features if you understand it better doing it with the base properties don't sweat it.
Jim Kinneman
Senior Consultant
Encompass Solutions
--- In vantage@yahoogroups.com, effgroups@... wrote:
> Hi all,
> Can anyone point me where I can find a explanation on all properties offered on controls in customizations?
> In particular I'm trying to create a combo box with static data but it should have 2 columns one for the data saved in the table and a second for the description.
> Can it be done? How?
> I couldn't find anywhere help on all the properties available.
> Thanks
> Ephraim
> Ephraim Feldman
