Hi Jim,
It locks only when doing the capture COS/WIP activity.
Regards,
Ellappan.
Message: 10
Date: Wed, 27 Sep 2000 09:00:13 -0500
Subject: RE: FW: Issue 376492: Problem in Labor entry, unable to delete
or edi t labor details for a period of 2 weeks
Does it lock things if you just run the Inventory/WIP Reconciliation or
only
when doing the Capture COS/WIP activity?
Regards,
Ellappan.
Message: 10
only
> -----Original Message-----till
> From: Ellapan [mailto:ellapan@...]
> Sent: Tuesday, September 26, 2000 9:57 PM
> To: vantage@egroups.com
> Subject: [Vantage] FW: Issue 376492: Problem in Labor entry, unable to
> delete or edi t labor details for a period of 2 weeks
> Workaround for this is to use Labor adjustment option under Job
> adjustment but you can't delete the labor entries.
> Best Regards,
> Ellappan.
> Megatech Electronics Pte Ltd.
> Singapore.
> From: Ellapan
> Sent: Wednesday, September 27, 2000 10:14 AM
> Subject: FW: Issue 376492: Problem in Labor entry, unable to delete or
> edit labor details for a period of 2 weeks
> Hi All,
> FYI.
> In Vantage 4.00, Pls. don't run "Capture COS/WIP Activity" program
> your month end closing if you are require to edit labor detailsanytime
> before month end posting / closing.manual
> When you run the Capture COS/WIP without marking it for posting to GL,
> it still locks down the labor details for editing.
> I received the reply from support is:-
> It assumes that a customer who is not interfaced to GL is making
> journal entries from
> the reports and in order for the reports to tie out to that entry it
> will still lock down labor entries so they cannot be edited.
> Pls. let me know if you need any clarification on the same.
> Best Regards,
> Ellappan.
> Singapore.
