FW: MS-DOS Batch Files
That's right, it's not supposed to be in the list.
The message you received indicates that BAT is associated properly so
I'm stumped.
Sorry
Gerard M Wadman
Sr. Network Systems Engineer
Scandius BioMedical Inc.
11A Beaver Brook Road
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
http://www.scandius.com/
This e-mail is for the use of the intended recipient(s) only. If you
have received this e-mail in error, please notify the sender immediately
and then delete it. If you are not the intended recipient, you must not
use, disclose or distribute this e-mail without the author's prior
permission. We have taken precautions to minimize the risk of
transmitting software viruses, but we advise you to carry out your own
virus checks on any attachment to this message. We do not accept
liability for any loss or damage caused by software viruses
Behalf
Of Richard Bailey
Sent: Friday, April 27, 2007 8:20 AM
Subject: RE: [Vantage] FW: MS-DOS Batch Files
I Can't see BAT file type in the list, although if I try to add a new
BAT
entry I get an warning that "BAT is already associated with Windows
Batch
file".
Something odd also is that if I schedule a batch file to execute at a
given
time, it executes OK. If I try and run the same batch file by
double-clicking it, all I get is the black cmd.exe screen
<mailto:vantage%40yahoogroups.com> ]On
Behalf Of
Gerard Wadman
Sent: 27 April 2007 13:07
Open windows explorer
From the tools menu, select "folder options"
Click on the "File Type" tab
Find "BAT" in the extension list and remove it.
Behalf
Of Richard Bailey
Sent: Friday, April 27, 2007 7:16 AM
To: UserGroup
Subject: [Vantage] FW: MS-DOS Batch Files
I've now got a situation where double-clicking the .bat file opens up
System32/cmd.exe but doesn't run the batch file. If I then type in the
batch/macro file name the process executes OK.
Somehow the filename of the macro to run is not being passed to the
command
program.
Any bright ideas anyone?
<mailto:rbailey%40dudleyindustries.co.uk>
<mailto:rbailey%40dudleyindustries.co.uk> ]
Sent: 27 April 2007 09:18
To: UserGroup
Subject: MS-DOS Batch Files
Todays dumb question, what file should be associated with MS-DOS Batch
files
(BAT extension)?
For some as yet unknown reason, one of our PCs has started using Notepad
to
open/run .BAT files. How can I change the file type association to
correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Tel: +44(0)1253 738311
Mob: +44(0)7836 550360
Fax: +44(0)870 7628173
Somehow the filename of the macro to run is not being passed to the command
program.
To: UserGroup
Todays dumb question, what file should be associated with MS-DOS Batch files
(BAT extension)?
For some as yet unknown reason, one of our PCs has started using Notepad to
open/run .BAT files. How can I change the file type association to correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Of Richard Bailey
To: UserGroup
command
program.
To: UserGroup
files
(BAT extension)?
to
correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
I Can't see BAT file type in the list, although if I try to add a new BAT
entry I get an warning that "BAT is already associated with Windows Batch
file".
Something odd also is that if I schedule a batch file to execute at a given
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Gerard Wadman
Of Richard Bailey
To: UserGroup
command
program.
To: UserGroup
files
(BAT extension)?
to
correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Two thoughts...
1. Assocate .BAT back to Notepad then in the File Types (under Folder Options) see if it is there and Delete it. On "normal" systems it does not show up in the file type list so the system must be capturing it.
2. If #1 does not work try gerting it back into the file types assocated with cmd.exe but make sure under the advanced tab...select Open action...Edit and see if the Application used to Perform action has a %1 at the end of the string. This may help it to find the actual .bat file.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Richard Bailey
Sent: Friday, April 27, 2007 7:20 AM
file".
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On Behalf Of
Gerard Wadman
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf
Of Richard Bailey
To: UserGroup
command
program.
From: Richard Bailey [mailto: rbailey@dudleyindus <mailto:rbailey%40dudleyindustries.co.uk> tries.co.uk
To: UserGroup
files
(BAT extension)?
to
correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@dudleyindus <mailto:rbailey%40dudleyindustries.co.uk> tries.co.uk
More info:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/assoc.mspx?mfr=true
Richard Bailey <rbailey@...> wrote: I Can't see BAT file type in the list, although if I try to add a new BAT
file".
Gerard Wadman
Of Richard Bailey
To: UserGroup
command
program.
To: UserGroup
files
(BAT extension)?
to
correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Use the DOS ASSOC command to define the file association for a , bat file.
Ed Ortiz
Sr. Project Engineer
Manitex
P.O. Box 1609
3000 S. Austin Ave.
Georgetown, TX 78627-1609
Phone: (512) 942-3007
Fax: (512) 869-7550
file".
Gerard Wadman
Of Richard Bailey
To: UserGroup
command
program.
To: UserGroup
files
(BAT extension)?
to
correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
You can try this in a dos window:
ASSOC SYNTAX Displays or modifies file extension associations
ASSOC [.ext[=[fileType]]]
.ext Specifies the file extension to associate the file type with fileType Specifies the file type to associate with the file extension Type ASSOC without parameters to display the current file associations.
If ASSOC is invoked with just a file extension, it displays the current file association for that file extension. Specify nothing for the file type and the command will delete the association for the file extension.
EXAMPLES
assoc - would display a file association of each of the file extensions on the computer.
assoc .txt - Would display the file extension for a .txt file as shown below.
.txt=txtfile
.bat=batfile
I hope this helps!
Ed Ortiz
Manitex
P.O. Box 1609
3000 S. Austin Ave.
Fax: (512) 869-7550
file".
Gerard Wadman
Of Richard Bailey
To: UserGroup
command
program.
To: UserGroup
files
(BAT extension)?
to
correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Richard,
.BAT extensions are "special" extensions (much like .EXE, .COM, etc.)
these are not viewable in the file types area. If you try to create a
new batch file on your desktop...right click on the desktop and choose
New --> Text Document. Name it TEST.BAT if you get the usual icon then
copy and paste the contents of your other file to that one, if you don't
then we may have to dig deeper.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
317.578.2393
jason@...
Of Richard Bailey
BAT
Batch
file".
given
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of
Gerard Wadman
Behalf
Of Richard Bailey
To: UserGroup
command
program.
To: UserGroup
files
(BAT extension)?
to
correct
this problem?
Thanks in advance
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
